G35 & G37, Coupes & Sedans
Old Oct 15, 2015 | 10:19 AM
  #5056
Spartan268's Avatar
Originally Posted by Tyke420
I'm getting the tip of my **** polished this weekend...
Sounds like a good weekend
Old Oct 15, 2015 | 11:35 AM
  #5057
MooseLucifer's Avatar
5 Year Member
blk
After being shipped to the wrong address, and sitting in a warehouse for a week, I'm finally getting my used Nismo Z-tube in the mail today
Tomorrow I'll install that, adjust my e-brake, and reset my drivers window regulator.
Old Oct 15, 2015 | 12:25 PM
  #5058
saywat?'s Avatar
Why do people often call the window motor the regulator? And Wtf is a nismo z tube?
Old Oct 15, 2015 | 12:35 PM
  #5059
BradMD_96's Avatar
I think the Z tube is simply the intake tube from a 350z, so that will be a Nismo intake tube for a Z
Old Oct 15, 2015 | 12:37 PM
  #5060
BradMD_96's Avatar
Originally Posted by LoSt180
Are you rebuilding your engine? Mine just started burning oil like it's going out of style and am considering a rebuild.
Nope, the headgaskets went on both side.....
I bought the car like that, then it overheated really bad and lost enough compression that it wouldn't start
Old Oct 15, 2015 | 01:29 PM
  #5061
5 Year Member
blk
@BradMD_96 is correct. I saw a Z in a scrap yard on craigslist, had the Nismo CAI, retails for $300 got it for $100. For now I'm just going to use the upper 'Z tube' part with my stock airbox. When I can find a stock lower plenum I'm going to do a DIY MREV2 mod and then I'll probably go with the CAI cone filter.
My mistake on the regulator/motor nomenclature, I used to have an EK Civic, and the forums are full of window regulator problems, so that word is stuck in my head.
Old Oct 15, 2015 | 07:45 PM
  #5062
SUMBLAKDUDE's Avatar
Ordered tein tire rods (inner and outer).
Has anyone used Rocar or P2M end links? Since I've upgraded sway bars wanted to changed those out and I don't track car and I'm not slammed to justify the price of the white line or spl ones.
Old Oct 15, 2015 | 08:40 PM
  #5063
saywat?'s Avatar
what is a cai cone filter? is that different from other cone filters?
Old Oct 15, 2015 | 09:24 PM
  #5064
RobertGST's Avatar
Maybe he meant the tube part of it that puts it behind the fender. Im not sure but does the nismo intake use the stock plastic thing that routes air from the grill behind the hood? Or does that also go behind the fender?
Old Oct 15, 2015 | 10:19 PM
  #5065
saywat?'s Avatar
or maybe he just doesnt really know wtf hes talking about
Old Oct 15, 2015 | 10:39 PM
  #5066
RobertGST's Avatar
Not nice, but maybe lol.
Old Oct 16, 2015 | 07:44 PM
  #5067
Frostbite91's Avatar
did the clutch pedal adjustment I learned from here (http://my350z.com/forum/g35-g37/4391...great-mod.html) Took about 2 minutes to do. Now my clutch pedal sits even with the brake pedal, and full disengagement is a little before it hits the floor. For the first time I can actually feel the clutch disengage through the pedal, instead of just memorizing the placement. All in all very happy, and starting from a stop is much easier.
Old Oct 17, 2015 | 08:13 PM
  #5068
Frankieg35's Avatar
Thinking of doing this lip and putting the Nismo on hold for now....
Old Oct 18, 2015 | 12:53 PM
  #5069
whutch1's Avatar
Front Lower Rear Compression/Control Arms
Front Upper Control Arms
Front Sway Bar End Links
Front Sway Bar Bushings
Front Lower Front Control Arm
Front Wheel Bearings & Hub assemblies (...and Rear)
Front Rotors (Drilled & Slotted) with Ceramic Brake Pads (... and Rear)
Front Knuckle Ball Joints
Replace tires with Cooper Zeon RS3-A
Tokiko Blue Struts
Optima Gold Top Battery
Radio Transmitter with Bluetooth Adapter ($65 total fix)
R2C Air intake
All done this year. No mechanic needed as all the work done by myself.
Next up: Replace all the bushings in the rear suspension components. Replace the Rear upper control arms with ball joints. Replace the rear shocks & mounts.
Cat Back Exhaust into a true dual with rolled exhaust tips.
2003 AT Staggered
Old Oct 18, 2015 | 02:57 PM
  #5070
JKL1031's Avatar
well someone has their priorities skr8..
