G35 & G37, Coupes & Sedans
Old Jun 7, 2016 | 10:24 AM
  #6211
BradMD_96's Avatar
Originally Posted by Wrathernaut
Replaced the passenger side radiator fan motor.
About a 15 minute job if you know what to do from doing the driver's side last year.
$100 down the drain for a new motor though.
Also had to replace the front wheels because of the destroyed bushing that caused SEVERE wear to the inside edge of my driver's side wheel. Looked like 80% tread left everywhere except the inside inch, which had plies showing.
So it's been an expensive month for my car. Throttle body, tires, radiator fan, and oil change puts me at nearly $1k.
What happened to your original fan motor, did it just stop kicking in unless you gave the fan a quick push to start spinning?
They usually fail when the motor brushes get stuck. Usually a combination of the brush fitting very snug, build up of dust and weak brush springs. Opening them up, sanding the brushes slightly smaller, stretching the springs/replacing with stiffer and a bit of oil/grease fixes the problem. - Just in case the other one fails soon. Also the problems tend to show after the car/fans aren't used for a while.
Old Jun 9, 2016 | 02:39 PM
  #6212
DigitalDeviant's Avatar
Today I was able to run up to the shop for a quick minute to get some final measurements for the rear seat delete and installed my seats, carbon wrapped jdm trim (which is for sale guys) and just some other random things.
The gap is because the radio is not the right size.
Old Jun 9, 2016 | 11:17 PM
  #6213
Red Shogun's Avatar
Garnet Ember G35X Sport EBC rotors LEDs GTR button Tail-as-Turn TBW undertray Alarm shock sensor
After finding out today that my G35xS will give absolutely no warning before the POS "Plus Start" battery dies, 3 yrs and one month after it was installed. (Furthering my theory
that cheap batteries, OEM or Aftermarket, WILL die after three years.) I put a DVM on it and it read 6.34V. After putting a battery charger on it long enough to open my trunk and get out my tools to change it out, I went to Pep Boys Online and ordered a Bosch Platinum Series AGM w/4yr replacement warranty and 3 yr roadside assistance.
Old Jun 10, 2016 | 02:21 PM
  #6214
Genthusiast35's Avatar
Replaced the rotors and pads on all four corners, and flushed out the old brake fluid. Found out that all four caliper brackets had at least one guide pin rusted in solid. This is what happens when you don't do stuff yourself smh.
Old Jun 10, 2016 | 04:29 PM
  #6215
Frostbite91's Avatar
un-plugged the yaw rate sensor from the G. Finally I dont have to hit that stupid VDC button every time I start the car. I really do dislike traction control, then again, I learned how to drive cars without it.
Old Jun 10, 2016 | 09:57 PM
  #6216
PhoenixG35's Avatar
Got the G dyno'ed today. Videos on my YouTube channel
https://www.youtube.com/channel/UC4v...JVQ31p9vGNtKfA
Old Jun 11, 2016 | 12:25 AM
  #6217
Albanian122's Avatar
Started the bay
Old Jun 11, 2016 | 05:48 AM
  #6218
LoSt180's Avatar
How are you driving that's causing traction control to kick in every time you drive? I can understand for a track day, but every time you start the car? Something is either broke or you're a reckless driver.
Old Jun 11, 2016 | 03:40 PM
  #6219
not reckless, you just cant drive like an old lady and wait 10 minutes for traffic to clear out. gotta jump in when you can. if i had an auto it prob wouldnt be a big deal, but i've always hated TC nonetheless. i know how to handle my car, dont need it bogging down when im trying to merge. idgaf if the tire slips for 1/10 of a millisecond. if we had an option for less aggressive tc i prob wouldnt mind it.
Old Jun 12, 2016 | 01:55 PM
  #6220
Conissah's Avatar
Finished my cooling panel. What you guys think?
Old Jun 12, 2016 | 02:15 PM
  #6221
JG_G35's Avatar
That came out great! You cut it yourself?
Old Jun 12, 2016 | 02:20 PM
  #6222
Conissah's Avatar
Yep, using a pair of tin snips for the outside and then a dremel for the inner portions.
Old Jun 12, 2016 | 02:40 PM
  #6223
JG_G35's Avatar
Wow, props! The cuts look real clean.
Old Jun 12, 2016 | 03:14 PM
  #6224
Conissah's Avatar
Thanks man. I have enough aluminum for 4 more if anyone is interested.
Old Jun 12, 2016 | 04:47 PM
  #6225
JG_G35's Avatar
How much would you sell them for?
