G35 & G37, Coupes & Sedans
Old Jan 31, 2017 | 09:02 AM
  #6961
Urbanengineer's Avatar
Looks good ^ I'm happy with LED In my rear housings tho, much less cutting involved !
Old Jan 31, 2017 | 10:32 AM
  #6962
Albanian122's Avatar
Originally Posted by zenkig
New winter wheels.
your brave those winter wheels in NJ
Old Jan 31, 2017 | 10:33 AM
  #6963
Originally Posted by .cakestar
testing testing testing
.cakester that looks amazing let me know if you make more I'd buy the inner led board from you
Old Jan 31, 2017 | 10:38 AM
  #6964
zenkig's Avatar
Not brave, stupid and impatient.
Old Jan 31, 2017 | 10:40 AM
  #6965
Be careful it's snowing
Old Jan 31, 2017 | 10:47 AM
  #6966
He has them, you have to cut the tails though as they use a permanent seal type holder to keep the two ends sealed together. He designed his own boards and soldered his own LEDs!
Old Jan 31, 2017 | 02:11 PM
  #6967
So how difficult is that
Old Jan 31, 2017 | 02:36 PM
  #6968
.cakestar's Avatar
there are some guides to follow. its not all that hard. basically just following along the edge with a dremel wheel. good place to start:
https://g35driver.com/forums/lightin...aillights.html
I need to redesign the lens diffuser still, if you study the oem lights vs mine the oem ones have the light broke up a little more, looks more like little squares
Old Jan 31, 2017 | 04:25 PM
  #6969
.cakestar's Avatar
i need to stop buying ****
Old Jan 31, 2017 | 04:38 PM
  #6970
SPL control Arm ???
Old Jan 31, 2017 | 04:39 PM
  #6971
.cakestar's Avatar
front camber arm and rear midlink, been looking for the rear camber arms but havent found any used. im running the kw v2's so its oem style with the spring bucket. wanted to keep the oem style setup so i opted for the spl midlink upgrade
Old Jan 31, 2017 | 04:48 PM
  #6972
Any benefit to the midlink upgrade I'm also running the KW Varient 2s
Old Jan 31, 2017 | 04:50 PM
  #6973
.cakestar's Avatar
you can use an eccentric lockout on the spring bucket which will allow you to adjust the toe and no chance of the toe going out of spec.
Old Feb 5, 2017 | 07:45 PM
  #6974
LoSt180's Avatar
Tested UpRev ARC burnout mode..
Old Feb 5, 2017 | 08:18 PM
  #6975
EPiK's Avatar
Hehe..looks nice guys. So UPREV has an update?
