G35 & G37, Coupes & Sedans
Old Aug 4, 2017 | 02:49 PM
  #7486
FreshLikeAG's Avatar
Originally Posted by LoSt180
ceramic film is very common for all tint. I'm referring to specifically 3M Crystalline Series tint. They have a very light, almost clear, shade that's barely noticeable.
I drove my brother-in-law's car with a tinted windshield and couldn't stand it at night. It was ok in town, but as soon as I got out where there are zero street lights it was pretty sketchy.
So far I just slap up a sun shade in the summer.
So you would say yes to the 3m clear film but no to any film with a tint to it?
Old Aug 4, 2017 | 09:56 PM
  #7487
Edgarc6789's Avatar
Sandblast done
Sprayed dtm done
Sanded flat and sprayed 2k done
Now need to sand flat spray n clear and choose some tire sizes
Old Aug 5, 2017 | 05:46 AM
  #7488
slicrick's Avatar
Car had been feeling a bit sluggish, rough-ish idle, and noticed the throttle response wasn't as good as it should be. Almost as if it had a bad coil pack or other ignition issue.
I cleaned the MAF, throttle body, and replaced air filter a couple of months ago just as regular maintenance, I never reset the ECU or relearned the throttle body. Today I had some time to kill and was bored so I tried it along with Accelerator Pedal Release Position Learning, Throttle Valve Closed Position Learning, and Idle Air Volume Learning (Throttle Position Learning).
Idles much much smoother, throttle response is sharp again, transmission shifts quicker and firmer. I overlooked the importance of doing this and would recommend anyone with a higher mileage car that might not be driving the way it once did to give it a shot, it's quick and easy and who knows when it was last done, if ever.
Instructions for everything are here: http://www.nicoclub.com/archives/g35...procedure.html.
Old Aug 5, 2017 | 07:11 AM
  #7489
.cakestar's Avatar
get those widened to 10.5
Originally Posted by Edgarc6789
Sandblast done
Sprayed dtm done
Old Aug 5, 2017 | 07:06 PM
  #7490
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Pedal dance reset for ECU, throttle position, throttle closed, idle air. Cleaned up a little pinging issue I was having as low RPM/throttle position under load.
Old Aug 5, 2017 | 10:53 PM
  #7491
Edgarc6789's Avatar
I tried to that to fix my 900 rpm idle I can't get it -_-
Old Aug 6, 2017 | 01:32 AM
  #7492
NjMatteSedan's Avatar
Originally Posted by Swaglife81
This reply is useless without pics. Like a girl telling you she just got implants wearing a big heavy coat and doesn't show you the work. Whenever time allows I'm gonna finish piecing together my audio build. I'm starting on a CLD, CCF, MLV with butyl strips in cracks and crevices. What brand/amps did you go with. Did you keep the factory B+ hooked up? What about alt to starter connection. I don't have a crimper so I was debating ferrule sleeves in set screw connections
did not do the install so I don't know the details, I had the big 3 kit laying around
this is the kit I purchased
http://www.ebay.com/itm/XS-Power-BIG...MAAOSwcLxYCotE
The alternator I also had sitting in my garage months till I got it installed, I bought it on ebay new, I don't remember the brand but it's 180 amp, they have some higher amp (240)
Old Aug 6, 2017 | 01:57 AM
  #7493
Edgarc6789's Avatar
Those eBay amps don't give what they say until your like at 6rpm.
Good alts give good power at stock idle but those are extremely expensive
Old Aug 6, 2017 | 12:21 PM
  #7494
Urbanengineer's Avatar
You could get a ticket for having tint on your wind shield, and it reduces night vision, so our recommendation is to get CLEAR TINT!
Old Aug 6, 2017 | 12:23 PM
  #7495
Do you wanna run outta power? Gotta spend money where it matters.
Old Aug 6, 2017 | 03:10 PM
  #7496
Edgarc6789's Avatar
No that what was my point lol
I hace a 320a amp and a 3400xs battery with 0 gauge big 3 ofc wire in my truck still dims-_-,
Old Aug 6, 2017 | 06:52 PM
  #7497
cleric670's Avatar
BANNED!!!
Did you make sure to use an actual timer? Counting in your head won't work it has to be VERY accurate.
Old Aug 6, 2017 | 07:02 PM
  #7498
Edgarc6789's Avatar
no just off my head
i plan on tuning my car real soon that should fix the idle too right....
Old Aug 6, 2017 | 11:15 PM
  #7499
BradMD_96's Avatar
Changed out the front main seal. Wasn't 100% sure if it was the source of the oil leak, but after removing the old one I could see it was hard/brittle and cracked. (pic too large to upload)
Just as I was tying up the repair I found the rad drain plug leaking, a half turn more and it snapped off so I had to improvise till I pick up the replacement tomorrow morning.
Old Aug 7, 2017 | 10:23 AM
  #7500
LoSt180's Avatar
no just off my head
Bluetooth obd dongle and ndsii app, warm up car then tap a button. So much easier than that perfectly timed pedal dance bs.
