G35 & G37, Coupes & Sedans
Old Dec 25, 2017 | 08:32 PM
  #7996
Urbanengineer's Avatar
Shouldn't you go to the dealer and make sure it isn't serious instead of a shade tree mechanic working on it
Merry Christmas!
Old Dec 25, 2017 | 08:46 PM
  #7997
LoSt180's Avatar
Merry Christmas!
lol, no. I always clear codes then troubleshoot if they come back.
Old Dec 25, 2017 | 09:08 PM
  #7998
ScraggleRock's Avatar
Originally Posted by telcoman
Got a SES warning lamp indicator
Hooked up my Actron scanner which showed a P420 Bank 1 code
Erased the code and drove around 20 miles so far.
Hope it doesn't come back
Telcoman
It will. Milage doesn't matter with warning lights like CELs and SESs. It's heat cycles. Usually 3 complete heat cycles is a complete rescan period.
Old Dec 25, 2017 | 09:18 PM
  #7999
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Easy enough to remove the cats and inspect for obvious signs of damage.
Old Dec 30, 2017 | 06:57 PM
  #8000
cleric670's Avatar
BANNED!!!
Chinook wind melted all our snow/ice so took this opportunity to replace a back up light that burned out a week ago. Got to once again cut through layers of dynamat and mastic tape over the screw access holes.
Old Dec 30, 2017 | 08:48 PM
  #8001
LoSt180's Avatar
Had a dusting of snow, took it out for some hooning to test my new VDC kill switch. It was fun.
Old Dec 31, 2017 | 09:38 AM
  #8002
True freedom ha ha. Before you had to slide backwards or totally lose control with VDC off to activate the Yaw off haha.
Old Dec 31, 2017 | 04:01 PM
  #8003
cleric670's Avatar
BANNED!!!
Do you guys know if anyone has tried using the factory VDC button with maybe a relay wired to factory stuff to actuate the kill switch? Basically just making the factory switch function as a 100% kill switch.
Old Dec 31, 2017 | 09:55 PM
  #8004
I mean it's pretty simple. Wire for the Yaw sensor goes in the active circuit where the switch is the VDC button clicked off. It's way more fun pressing the big red button in the cubby.
Old Jan 9, 2018 | 09:01 AM
  #8005
wuzz-upp's Avatar
Yesterday,
During the past few month, I've had an intermittent OBD II code P0304, the # 4 cylinder was misfiring. I removed and replaced the coil, while I was at it I decided to go ahead and replaced the O-rings on the left and right bank camshaft position sensors. I should have replaced them a while back when I sealed the vale covers. The valve covers are still oil leak free after a year or more.
Old Jan 24, 2018 | 09:30 AM
  #8006
CFE4130's Avatar
Originally Posted by CFE4130
Thanks for the constructive criticism. Made some changes a couple of months ago.
Old Jan 24, 2018 | 01:54 PM
  #8007
You painted it blue?
Old Jan 24, 2018 | 02:12 PM
  #8008
CFE4130's Avatar
Yes
Old Jan 24, 2018 | 10:29 PM
  #8009
Very nice! Love the color.
Old Jan 24, 2018 | 11:32 PM
  #8010
Edgarc6789's Avatar
How much :0
