PCV valve
16x1.25 and if you're looking for a delete to screw into the hole I think literally the only one on the market is the Project Import pcv to -8AN fitting because it's a nonstandard size.
thanks for the feedback, sucks cause I don’t think they ship to Canada.
There's also the option of drilling out the factory one but it's a pain because there's a piece inside that will spin. I recommend buying a second one and super glueing the valve inside so it no longer spins then you can drill it out.
Gary
My plan was to replace the PCV valve with a hollow fitting and attach a filter to vent all the blow by out instead of it getting re-routed back to the lower plenum.
Once drilled out what would be the point though? you wouldn't be able to connect any fitting to it after correct?
