G35 & G37, Coupes & Sedans
6mt trans tricky to get into reverse?
Old May 2, 2019 | 06:41 PM
  #31
Ichiglo_'s Avatar
Can you guys help me? My aftermarket shift **** came off loose by its own so I decided it was the perfect time to switch back to my oem one but as I was trying to screw the oem back on it didn’t want to go in?? Is that metal ring required to install the oem one back on?
Old May 2, 2019 | 06:50 PM
  #32
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yep, the one at the top is the "seat" in this picture.
Old May 2, 2019 | 06:52 PM
  #33
Ichiglo_'s Avatar
So how would I go about removing it? Do I just remove in and throw on the shift **** hole? Or whatever the bottom end is called
Old May 2, 2019 | 07:11 PM
  #34
cleric670's Avatar
BANNED!!!
Not sure I've never removed the seat from the OEM shift assembly, it probably just unscrews though.
Old May 2, 2019 | 07:12 PM
  #35
cleric670's Avatar
BANNED!!!
It doesn't come installed in the OEM shift **** though, it goes on first then the **** screws on. There are a LOT of threads though, are you SURE it wasn't screwing on?
Old May 2, 2019 | 11:17 PM
  #36
Ichiglo_'s Avatar
Got it in i just need to press it and turn super hard this time I used vice grips under the shifter and turned liked hell but now my car feels like when I first bought it
Old May 2, 2019 | 11:48 PM
  #37
Ichiglo_'s Avatar
Only thing now is that I noticed 5th and 6th gear and kinda hard to get into (I hope it’s not my tranny as I don’t really drive the car that often for it to be damaged) 1-4th gear go in no problem and reverse goes in to
victor0206
Nov 19, 2017 09:21 PM
Gian124
Jan 30, 2008 06:27 PM
gregip1
Dec 4, 2007 04:32 PM
superchargedg
Forced Induction
20
Nov 14, 2007 03:26 PM
snboarder84
Mar 24, 2004 02:05 PM
