G35 & G37, Coupes & Sedans
Aftermarket Radio Not Working!!!
Old May 8, 2020 | 11:21 PM
kingmiles21's Avatar
G35 Coupe
I’m currently using a NOEM-NIS2 for my 2005 Infiniti G35 Coupe. I have everything hooked up to my aftermarket radio but it’s not working. The radio isn’t getting any power. It’s a Kenwood DDX5706S. Any help is appreciated!!!
Old May 9, 2020 | 08:02 AM
telcoman's Avatar
Veteran: Army
Did you check for a possible blown fuse?
Old May 9, 2020 | 10:52 AM
G35 Coupe
Yes, the radio fuse is good. I even placed the factory radio back in and it works fine. When I have the aftermarket one installed, the cooling fan on the back spin for 2 seconds and stop. It keeps on doing that.
Old May 9, 2020 | 11:17 AM
telcoman's Avatar
Veteran: Army
So you have a defective aftermarket radio!
Return and replace it or use the factory radio.
Problem solved!
Old May 13, 2020 | 07:00 PM
srv2nv's Avatar
G35 Sport
Make sure there's no power button that needs to be pushed to turn it on for initial start up. Had a Pioneer like that.
Old May 13, 2020 | 08:43 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
Make sure the antenna is plugged in. It's one of the factory grounds.
Vq35sedan1stGen
May 13, 2015 07:42 PM
wiy
Jan 25, 2015 11:10 PM
Carmelo
Aug 6, 2013 08:59 AM
newyorkg35
Sep 21, 2010 07:36 PM
str8dum
Jan 23, 2004 03:17 PM
