G35 & G37, Coupes & Sedans
No Start ‘05 G35 ECM questions
Old Apr 29, 2022 | 06:20 PM
Ol55's Avatar
Stock sedan
Background No start before winter, trying again. Good fuel flow and pressure to rail, runs on starter fluid, Immobilizer seems normal (no red ring. Ran well before.
Would like to check the ecm. What can I do to eliminate the ecm as the cause? TIA
Old Apr 30, 2022 | 04:47 AM
Scorpi0's Avatar
If its running on starting fluid, that means your ECM is working fine.
Old Apr 30, 2022 | 11:08 AM
Ol55's Avatar
Stock sedan
While It’s out…
Thanks. Should I get the immobilizer deleted while I have it out?
Old Apr 30, 2022 | 02:41 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
No, focus on why the car isn't running before you go changing other things that might also impact the vehicle's ability to run.
How are you testing for fuel pressure?
Are any of the spark plugs wet after you crank the engine for a while?
Old Jul 1, 2022 | 09:08 AM
Boanz's Avatar
G35X sedan
I hope u got the problem fixed but if not I’d start by listening to injectors while cranking car if you don’t hear them clicking they probably aren’t spraying fuel you can use a stethoscope they are cheap if it runs on starting fluid and there’s pressure at the rail then it seems your eco is working I would think your injectors aren’t spraying also check for power at the injectors you can rent noid lights at the auto parts stores they plug into the injector plug and you can watch to see if there is a signal/power at injector it should be flashing fairly quick when cranking car hope this helps if no click or flashing injectors aren’t firing and it could be a short very slim chance it’s ECM gl hope this helps
Old Jul 14, 2022 | 07:01 PM
Wall113's Avatar
07 g35 coupe 6 speed manual
Did you ever get this figured out
holly9787
Jan 2, 2019 05:39 PM
b_dupy
Oct 12, 2016 09:04 AM
alexp96
Dec 22, 2015 02:59 AM
yosip1115
Mar 25, 2013 08:43 PM
venom81
Sep 14, 2009 09:50 PM
