G35 & G37, Coupes & Sedans
Abs vdc slip an flashing AWD light
Old Jul 19, 2023 | 07:53 PM
StevenDeYoung's Avatar
Broken atm
The other day I noticed a weird sound coming from the front right passenger side well after some looking around I found it was the hub assembly great right? Well not so much after replacing the hub assembly with the exact same one that was in just new an apon starting the car I notice that the ABS VDC SLIP was on solid an the AWD was flashing I took it around the block to see if anything was noticeably wrong an I noticed the car was in RWD an that the traction control was not working properly, (I bled my brakes after putting the new hub on) anyone have any ideas on what it could be? Trying to avoid taking it to a dealer if I don't need to
Old Jul 22, 2023 | 10:37 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably the wheel speed sensor isn't installed correctly, I'm sure it's throwing codes too.
Old Jul 23, 2023 | 02:34 PM
Broken atm
It was the speed sensor the connectors at the end were actually corroded an once I installed a new speed sensor 96$ later it works fine again thank!
Old Jul 28, 2023 | 10:57 AM
cleric670's Avatar
BANNED!!!
Awesome, glad you got it all sorted out.
asaini09
Jan 7, 2012 06:03 PM
One_Hertz
Sep 10, 2008 03:20 AM
Cyanide Ride
Feb 12, 2007 02:28 AM
2Evolved
Mar 17, 2006 03:07 PM
paulcl
Jan 13, 2006 05:48 PM
