G35 & G37, Coupes & Sedans
Metal flakes in oil pan! Ahhhhh!
Old Jul 31, 2023 | 12:12 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I can't really tell from the picture but does the timing chain guide look like it's all in good condition?
Next up would be to pull valve covers and see what it looks like up top.
Old Jul 31, 2023 | 06:10 PM
Mg35gt's Avatar
2006 G35 6MT Premium w/ leather seats
I also keep finding a little metal ***** and I have no idea where they’re coming from
Old Aug 2, 2023 | 11:49 PM
Mg35gt's Avatar
Ok I tore down my spare junk vq rev up to try and find something similar to the parts I found in mine but no luck. I’m just going to fix my gallery gaskets slap it back together and see what happens. If it does break I’ll just build my motor for boost then!
Old Aug 5, 2023 | 11:15 AM
cleric670's Avatar
BANNED!!!
Ok if you're ending up with ball bearings then those are oil check valves, there will also be a little spring with them which explains the spring you found earlier too. The only one I'm aware of is in the oil filter sandwich adapter. You should pull the oil cooler sandwich plate and see if that's where the carnage started.
Old Aug 5, 2023 | 02:34 PM
Mg35gt's Avatar
OK I pulled the oil s sandwich and guess what? It’s still intact 😂!
Old May 8, 2024 | 09:47 PM
jaydice's Avatar
Vq35HR
you ever find what that spring was for? I just pulled my oil pan yesterday and found the exact same spring😐
Old May 10, 2024 | 01:26 PM
Mg35gt's Avatar
I still have absolutely no idea what it was from, my best guess was part of the rear main seal but still not sure. I haven’t driven it much after I put it back together, cause It’s getting body work done but I did put a lot of idle hours on it since and it runs and drives just fine. Hope yours works out like mine hopefully has!
Old May 10, 2024 | 07:07 PM
jaydice's Avatar
Vq35HR
sooo i just took off both timing covers front and rear, and it was determined it was the main seal “. Theres a little a spring in there , i guess it fell out or w.e appreciate the help bro
supkoop
Sep 17, 2021 11:29 AM
CV35Driver
Mar 18, 2015 09:54 AM
speedcretin
Aug 23, 2012 09:18 AM
officerdbag
Oct 27, 2009 10:28 AM
kevkel
Apr 27, 2007 10:52 PM
