G35 & G37, Coupes & Sedans
Really Cool Unknown Features
Old Nov 12, 2007 | 03:57 PM
  #136
O HELLA OEM's Avatar
interesting!
Old Nov 12, 2007 | 04:10 PM
  #137
Jedunnigan's Avatar
Originally Posted by 04_SKyL!N3
i have an 04 what is the proper setting ? teach me
Lol.
Old Nov 13, 2007 | 07:05 PM
  #138
jvelos3's Avatar
found this out while washing the G...it automatically locks after like a minute or 2.
Old Nov 13, 2007 | 07:29 PM
  #139
Beebo's Avatar
what year is your G and is it a coupe or a sedan?
Old Nov 13, 2007 | 08:43 PM
  #140
dave's Avatar
It only does that if you unlock it with the remote and then don't open a door. After a minute or so it re-locks itself.
Old Nov 13, 2007 | 09:55 PM
  #141
d_pak's Avatar
Re-programming or Adding New Key FOBs
Yes, all Nissan/Infiniti vehicles auto-lock themselves if the Key FOB is used to unlock it, but the doors are not opened within 90 sec. sometimes can be frustrating, but can also provide security.
If you get intercepted by a friend in a parking lot who drags you in for another drink....don't have to go out there and check if you left your car unlocked.
Contribution to the thread:
Inserting and Removing the Key from the Ignition 6 times in 10 seconds immobilizes the vehicle and renders all KEY FOBS useless. Want to really mess with someone's G or Nissan for that matter...insert your key in his/her car's ignition 6 times in 10 seconds.
After he starts crying perform the following procedure. It can also be used to add up to 5 Key FOBs to 1 Vehicle. This is useful when you want an aditional key or can be used to erase old FOB programming from vehicle in case you lose a key FOB.
KEY FOB ID CODE ENTRY PROCEDURE
Step 1) Sit in drivers seat, close and lock all doors.
Step 2) Insert key into and remove it from ignition key cylinder more than six times within 10 seconds. (Hazard warning lamps will then flash twice).
NOTE: Withdraw key completely from ignition key cylinder each time. If procedure is performed too fast, system will not enter registration mode.
Step 3) Insert key into ignition key cylinder and turn to ACC position.
Step 4) Push any button on remote controller once. (Hazard warning lamps will then flash twice). At this time, the oldest ID code is erased and the new ID code is entered.
Step 5) Do you want to enter any additional remote controller ID codes?
A maximum of five ID codes may be entered. If more then five ID codes are entered, the oldest ID code will be erased. If you do not want to enter any additional remote controller ID codes, go to Step 9).
Step 6) ADDITIONAL ID CODE ENTRY
Lock all doors with LH (driver side) lock/unlock switch (in main power window and door lock/unlock switch).
Step 7) Push any button twice on remote controller once, (Hazard warning lamps will then flash twice). At this time, the oldest ID code is erased and the new ID code is entered.
Step 8) Do you want to enter any additional remote controller ID codes?
If so, unlock doors then repeat Step 6) and Step 7).
Step 9) When complete, open door, and check operation of remote.
Old Nov 13, 2007 | 10:41 PM
  #142
OCG35's Avatar
^^^ all very interesting... not sure I'll ever use it, but interesting.
Old Nov 13, 2007 | 10:45 PM
  #143
GeezerB's Avatar
Anyone know how to get my key to turn on the ignition? My second dealer provided key stopped working. It can be inserted in ignition (2004) but when turned, the motor just cranks without starting. It was stored in a dresser drawer for years & now is useless. Remote still works but only opens doors.
Old Nov 13, 2007 | 11:13 PM
  #144
GForANewMechE's Avatar
...the motor cranks but won't start? Not to be obvious or disrespectful by any means but thats going to be filed under "mechanical problems" i believe. As in "my ***** broke" mechanical problems. Seriously though, if none of your keys will start your car you either have a mechanical issue (batt not fully charged, **** outta gas) or a random anti-theft occurence. Either way i'd be doing some searching and asking at this point.
Old Nov 13, 2007 | 11:15 PM
  #145
GeezerB's Avatar
Note...
My spare key will not start the car. My main key will. The service guy guessed over the phone that it must have come into contact with a magnetic field. He's paid way too much too guess.
Any more better suggestions?
Old Nov 13, 2007 | 11:30 PM
  #146
Note...
Ahh, sorry, understood it wrong. Would this be out of the question: drive up to the stealership on a saturday and say "Hey, i've got this key from dealer, it doesn't work (as per demonstration)... so fix it. K thanks. Oh, and while you're at it i would like these 13 not-so-well-known programming options customized (post #74). And give me a muffin... beeches (https://g35driver.com/forums/g35-coupe-v35-2003-07/116736-what-free-stuff-did-you-get-your-g-purchase.html post #6)"
Old Nov 14, 2007 | 12:01 AM
  #147
k67p67's Avatar
Your second key is not properly programmed (transponder recognition). Take it to the dealership to have them reprogram the keys. You will need to have ALL of your keys present when doing the programming. There are a handful of locksmiths that can do the work but the programmers cost several thousand dollars and most locksmiths won't have what you need.
Old Dec 8, 2007 | 09:02 PM
  #148
06g35meister's Avatar
did anyone know that above the passenger sun visor there is like a business cars holder of some sort? i just randomly noticed it today, thought infiniti was cool for thinking of that...
Old Dec 10, 2007 | 11:07 AM
  #149
Texasscout's Avatar
I just found this thread....
The people in my office think I'm deranged because I am laughing so hard.
Thanks for all the tips!
Old Dec 13, 2007 | 10:50 AM
  #150
Mr Inkredibul's Avatar
Originally Posted by clinty
Basically instead of your window pressing AGAINST a gasket/seal in order to make a weatherproof seal for your door, the G35 windows push up into a seal. It does this by lowering the window slightly when you open the door, and then raising it back into the seal when the door shuts.
Don't want to spoil your theory but the window comes down slightly so it doesn't scrub the frame at the top.
Sorry but you are wrong, it is in fact so that the windows pushes up INTO a seal instead of against it. It makes for a better seal.
