Bumper fitment!?!? Please help out
Hi guys>>> This is my first post... Well I will be needing a front and rear and also side skirts in ivory pearl... My car is an 03....
My question is will i need to repaint te bumpers if they come with the factory ivory pearl from the 03-06
Also will these parts be compatible and interchangeable with my car since it is an 03'.
Second... Do you have a sedan or coupe?
Third... If it is a sedan. The 03-04 bumpers front and back and side skirts are the same. The 05-06 are different and won't work for the bumpers. Not sure on the side sills. Usually if you order any of those parts, they will ask what color you have so that they can have it color matched. If they don't, try using this website: http://www.g35parts.com/9083/osc/index.php?cPath=26_34
That website will send the parts you need color matched. The color could be slightly off or right on, depending on the dye lot that they use and the condition of your car. Hope this gets you started.
06 sideskirts are different, but will fit. as for repainting, most factory painted parts should match fairly closely, but usually will not be perfect. however, even having them painted may not be perfect match either, unless you have them blended into the adjoining panels. that would mean blending into both quarter , both fenders and blending up into the doors for the side skirts. imo, unless you are very particular about paint match, finding factory painted parts should be good enough.
if you have a coupe (which i assume since this is the coupe forum) all bumpers and side skirts should fit..
there are now sport bumpers and sport skirts available for the 06 but these will fit on any year coupe..
apparently the sport sideskirts are on national back order right now though..
Yeah, there is a "view all posts" button. It is in the G-Spot section and the Engine, Drivetrain & Forced Induction section. I love it.
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
