Why is my G so slow
Old Aug 10, 2006 | 11:11 AM
  #31
truplay8's Avatar
THE BATMOBILE
must be the driver.........drop a turbo
Old Aug 10, 2006 | 11:23 AM
  #32
ExWRXDriver's Avatar
Originally Posted by trey.hutcheson
If you're shifting that early, then you're losing power. Sure, the engine may peak at 6200rpms, but the torque multiplication of 1st gear is great enough that you should shift at redline.
+100
This car is definitely fastest when shifting at redline, as are almost all cars, with the exception of diesel trucks, probably vipers, and possibly heavy turbo/supercharger applications.
250lb-ft*6200rpm*HPconstant = 218lb-ft*7100rpm*HPconstant
So unless your torque is dropping off by more than 30 lb-ft in that last 900rpm, then you should be shifting to redline. It's also important to consider the momentum lost in the 1-2 shift if you shift earlier than redline.
Also what he^^ was saying,
100lb-ft* ~3.8 (first gear) = 380 lb-ft
100lb-ft* ~2.3 (second gear) = 230 lb-ft
meaning lower gear equals more power to the wheels
To the thread starter-- It has to be the car if you still get spanked from a roll, obviously if the car's fine there's nothing else it could be but the driver.
Old Aug 10, 2006 | 11:27 AM
  #33
mrimage's Avatar
come oh guys be real here, how the hell a 05 g lost to a 03 z, thats not possible, the driver is the problem
Old Aug 10, 2006 | 11:43 AM
  #34
chilibowl's Avatar
What the f*ck are you guys talking about? The Z is a faster car and has ALWAYS BEEN the faster car, it may be by a tiny margin, but its still faster. Its possible to beat a Z but thats because the Z driver must suck terribly. If the drive of the Auto Z knew how to torque brake, he'll eat u up even harder. I think the problem here is the driver. Your launching way to high buddy, there is absolutely no reason to launch at 4.5K. Launch at 2.5K and dont give full throttle until you lock up, flooring it while still spinning doesnt help at all. Also, the whole f*cking point of the Rev-Up is the higher redline, take advantage of it, and shift at redline, you are producing peak power all the way upto it. Whoever posted to shift at 6200 is moron. The closer you shift to redline, the further you will be in the powerband in the next gear. Practice your launch and you should be able to edge out on the Z since he's auto.
Old Aug 10, 2006 | 01:21 PM
  #35
99atlantic's Avatar
Originally Posted by Klubbheads
6MT G with the right driver should spank(Yes spank 2-3cls till100) auto 350Z
No its not a drag car and no one expects it to be... But racing a auto 350z should be an easy kill with a 6MT.
Hardly. Maybe in 1940, but today the difference in tranny's is very miniscule in a 1/4mile run...maybe .1 at most, unless 1 gets unfavorable conditions.
Old Aug 10, 2006 | 02:29 PM
  #36
Captain Baller's Avatar
Sometimes it does happen and someone is the unfortunate and is given a slow car from the factory...my father was a engineer for GM for years back in the day so he knows alot about cars and he said he would remember with the corvettes you would have 2 of the same exact one roll of the assembly line and 1 would be 2 cars fast than the other for whatever reason...just happens sometimes. I have a 03 5at with cai and exhaust and i run 14.1 at 99mph i think i just happend to have gotten a fast G (or we broke it in perfect) cause i was beating this 350z that had exhaust, headers, pipes, and a CAI. he was running 14.3 all night at 98mph....i guess what im getting at is sometimes there is just a slow one out there have it looked at.
Old Aug 10, 2006 | 02:32 PM
  #37
^+1
Old Aug 10, 2006 | 04:13 PM
  #38
Calvin's Avatar
Overglorified Altima
just keep in mind that intakes really wont do much without aftermarket exhausts..
stock air filter works best with stock exhaust if you ask me..
Old Aug 10, 2006 | 04:27 PM
  #39
BoostedIS300's Avatar
yes the 350Z is the faster car and should pull auto or not by a minimum of a car length on the G 6mt or not .... for those of you who say you have beat Z's stock then you got lucky and the Z driver could not drive .... id ont know why your friend in the auto Z was posting 15 sec 1/4 mile passes because thats pretty sh*tty too,
moto of this post - 350Z is FASTER then the G stock for stock auto vs. 6mt it doesn't really matter.
Old Aug 10, 2006 | 04:50 PM
  #40
Klubbheads's Avatar
U don't know what ur talking about. If ur gonna reply to this post then u should live in Southern Cali to back ur statement up.
Old Aug 10, 2006 | 05:00 PM
  #41
kraqcommando's Avatar
why do you turn of VDC when you race
Old Aug 10, 2006 | 05:38 PM
  #43
vn3115's Avatar
When VDC takes over, it limits wheel spin by breaking and cutting engine power. With VDC off it won't interfere, and you can break the tires loose a bit.
Personally I would never turn it off unless the roads are dry. There are too many threads about I totaled my car on the freeway on ramp, with VDC off.
Old Aug 10, 2006 | 05:40 PM
  #44
UFGatorG35's Avatar
Originally Posted by pch2005
I think there is something seriously wrong with me G. I think it is just dirt slow. I raced my brother that has a 2003 350z auto and he spanks me...BAD. He ran a 15.0-15.2 @ 94-95 mph and he is spanking me by atleast two cars. Does anyone know why? I have a 2005 6mt coupe and i just can't seem to beat him and the car itself feels so slow. I redline about 7300 rpms or as close to 7400 as possible. And please do not say it is the driver . I want to take it to the track and see what i can really do, but i feel that i will just embarresed myself. I am bone stock right now, and i know this car is rated atleast 99pmh in the 1/4 and it is no where near that. My old car was way faster than this....
You've got to release the parking brake!
Old Aug 10, 2006 | 05:41 PM
  #45
redred7139's Avatar
check out that one.... https://g35driver.com/forums/g35-coupe-v35-2003-07/111576-vdc-no.html
