RESULTS: 6MT Tranny Problem
Old Oct 14, 2003 | 01:30 PM
G35Girlie's Avatar
Well, after 5 weeks at the dealer and me constantly insisting that something was wrong with my clutch or transmission, they finally got permission from Infiniti to start taking it apart and they found problem #1.
My pressure plate came apart from my clutch and was just spinning freely. It also broke my clutch into a million pieces. Apparently I drove with the car like this for a long time. It was not driver error, but an error from the assembly line of the car. How weird is that?!?!?! They said that they had never seen anything like it before. They replaced my bearings, clutch, and pressure plate and put it all back together and were going to test drive it today and see how it is now. I may not need the new tranny if all the problems go away with just the new clutch.
I will keep you posted on whatever else I find out
Old Oct 14, 2003 | 01:51 PM
G35Gnome's Avatar
Re: RESULTS: 6MT Tranny Problem
Nice, so you have it back now ? Will you run it tommorow at Etown ?
Old Oct 14, 2003 | 05:31 PM
G35Girlie's Avatar
no, the dealer never called about it today, so I didn't get it back yet...plus I have to break in the new clutch for 500 miles...there is no way I will do that before tomorrow. I will run my other car.
Old Oct 14, 2003 | 06:17 PM
GemmDeMoN's Avatar
Wow....this is kinda off topic...but my shift ****, it is starting to chip already!! You know where that little cap on top of the handle, where it says gears 1,2,3,4,5,6, and R???? well that is chipping!!! WTF?? anyone else have this problem?? or should i just make a new Post??
GemmDeMoN's Avatar
Old Oct 14, 2003 | 09:08 PM
g35fanatic's Avatar
my shift **** is just fine and dandy
2003 6MT Laser Red Coupe, Premium, Chrome 18's
Old Oct 14, 2003 | 10:39 PM
jgainsle's Avatar
G35Girlie: what were the symptoms of your broken clutch? My shifting is really notchy. In addition, it sometimes grinds when I shift even though I *know* I've got the clutch fully depressed...
thanks
2003 G35 Coupe 6MT Black/black
Bay Area, CA
Grounding wires - Z intake tube - clear corners
Old Oct 15, 2003 | 12:11 AM
ducatiguy's Avatar
Premier Dough Slapper
I "thought" my 6MT was feeling a little notchy as well, sometimes not getting into 2nd under hard acceleration (knowing 100% that I've cluthed it). I took it in and had service take a look at it. They claim nothins wrong, but atleast it's been recorded. One time I even noticed my clutch pedal drop all the way to the floor. No pressure what so ever. Everything worked fine, car shifted like normal, but it took no effort to press the clutch. Really weird huh? It lasted for a whole 5min and then tightened up. It's never happen again, nor has Infiniti been able to explain what went wrong. Nevertheless, like I said, its been recorded and noted so if I were to have any future prblems with my trans, they can't say well you should have brought it in....
Old Oct 15, 2003 | 08:28 AM
Haggis4All's Avatar
What were the symptoms before the fix? My G has a "rattle" noise all the way in first gear, and partway through second gear. Shifts fine, however. Anyone else get this?
Red '04 G35C 6MT
Old Oct 15, 2003 | 08:36 AM
G35Girlie's Avatar
Thats where I had the noise...When I would shift from first to second. When I would put the clutch in, it would sound like a lound spinning noise, then a clunk, then it would go away. Also, when I would be stopped or in first gear rolling, there was a rotating grinding noise. When I would put the cluthc in, it would go away, then I would take the clutch out and it would come back. I thought that was the throwout bearing. I also have a grinding/unsmooth shift into 1st and third gears
2003 Brilliant Silver 6MT
Injen Intake
Old Oct 15, 2003 | 10:58 AM
jmweidm's Avatar
my **** is chipping also!
G35Coupe B/B 6MT Aero/Premium
Old Oct 15, 2003 | 11:07 AM
ImportFreak's Avatar
i got the same thing. i coulda sworn that my clutch was in and yet it still grinded into second gear. so i dont kno wat to do. it hasnt happened again.
2003.5 II G35 II Coupe II 6MT II BS II Prem. II
Old Oct 15, 2003 | 02:30 PM
g35don40's Avatar
Just curious,
You folks with the chipping shift ****, do you wear rings on your right hand?
2004 6mt Laser/Graphite/Aero/Premium/BSM/splash
Old Oct 15, 2003 | 03:49 PM
jmweidm's Avatar
No rings on these fingers! But you bring up an interesting though. I think I will start a new thread asking my question. Check it out, I'll post it right now...
Old Oct 25, 2003 | 01:12 PM
Canton_G35's Avatar
I have some of the same problems.
grinding in 2nd 3rd and 4th. like it's a tooth off when I shift.
and strange noises coming from what I think is the clutch.
and a couple of times it felt like I just ripped it out of first when the clutch was to the floor. And I've been denied when shifting into 2nd 4th and 6th and had to release the clutch and press it again to get it to go in.
When I asked the dealer about it, they took it for a test drive and said they didn't notice anything. But they documented everything.
When i tried to describe the clutch noises, I said it sounded like cheap quality. and they service guy looked like he was about to have a heart attack. and went on to say I can't compare an Infiniti clutch to other clutches. blah blah blah....I guess I offended him a little.
2003 G35 Coupe 6MT/Black/Graphite/15% tint
