resetting the ecu?
Old Oct 23, 2006 | 02:50 PM
04Gwhiz's Avatar
resetting the ecu?
hey guys..is it true that you need to reset the ecu after you do an engime mod like exhuast, plenum etc? so the car can adjust to the new changes?
like i have a kinetix SSV, should i reset the ecu to get the car to adjust to the new air ratio?
Old Oct 23, 2006 | 03:16 PM
Dieselnuts's Avatar
ive heard that manifold really leans out the engine. If you get it tuned, i put money that you will get more out of your car.
Old Oct 23, 2006 | 04:02 PM
izmir41500's Avatar
G35driver Addict
short answer is yes. best thing to do is get it tuned after you're done with all your engine mods. or get a technosquare reflash or something similar.
brianyun's Avatar
word
04Gwhiz's Avatar
short of buying a performance chip..can the stock chip be retuned?is this acceptable?
Old Oct 23, 2006 | 04:17 PM
Calvin's Avatar
Overglorified Altima
^^send it in to technosquare
Old Oct 23, 2006 | 04:25 PM
04Gwhiz's Avatar
how do i get in touch with technosqaure?
all resetting the ecu will do nothing for me?
Old Oct 23, 2006 | 04:35 PM
ballisticus's Avatar
http://www.technosquareinc.com/contact.htm
Just doing an ECU reset has no effect since the stock maps can only accomodate very small flow modifications. All a reset does is clear any faults and return the "learned" parameters to default to start learning again. But once the stock fuel and timing maps are maxed out, that's it. And you will probably be lean.
I was in the low-mid 14's A/F prior to reflash. Adding 8% more fuel made a huge difference and allows more timing advance since it has less potential for ping when you richen up. If you're sure you're done with your mods, reflash is usually the lowest cost option.
Old Oct 23, 2006 | 04:58 PM
YngPhllyKd's Avatar
how much does it cost to get ur ecu reflashed?
Old Oct 24, 2006 | 12:59 AM
YngPhllyKd's Avatar
?? No one knows?
Old Oct 24, 2006 | 01:00 AM
Calvin's Avatar
^^about 500 bucks
Old Oct 24, 2006 | 02:48 AM
bobshuai's Avatar
so expensive.
Old Oct 25, 2006 | 06:39 PM
Originally Posted by bobshuai
so expensive.
Not really. When you consider that it optimizes the mods you already have. On my car, it was worth every cent.
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
MThawkins86
Oct 24, 2015 02:07 AM
vamarris
Sep 26, 2015 12:56 PM
