Rev light?
Old Oct 30, 2006 | 08:33 PM
justice76's Avatar
Rev light?
Can I get this thing to turn off? Thanks
Old Oct 30, 2006 | 08:39 PM
speedracerg35's Avatar
no. unless you pull the cluster and remove the bulb.
Old Oct 30, 2006 | 08:56 PM
shimmy's Avatar
just set the rev light to 8000 rpm
Old Oct 31, 2006 | 12:09 AM
i don't think he means the red light that comes on for the setable shift point, rather the orange light that says "rev"
Old Oct 31, 2006 | 02:00 AM
shimmy's Avatar
gotcha... so yeah, take out the bulb.
Old Oct 31, 2006 | 02:19 AM
justice76's Avatar
Yep its the yellow rev,, Sorry should have included some more info.. Well I guess I will learn to love the dummy light
Old Oct 31, 2006 | 10:18 AM
Imadriver's Avatar
I'm confused...do the 2006 Coupe 6MT have the red light? I haven't seen it.
But I do have a yellow "REV" light that stays on constantly. I keep expecting it'll turn off after I reach a certain number of miles, but so far (3000+ miles) it still stays on.
I remember this light from my test drive, it would only come on when the car neared the redline. I didn't realize you could change the point at which it activates. How do you do that?
I wasn't able to find anything in the manual about it.
Old Oct 31, 2006 | 10:52 AM
GT-Ron's Avatar
Push the data-stem on the cluster until it cycles to the RPM option (probably set at 8000). Once there, turn the stem to change the designated RPM to what you want. FWIW, the red light (below REV) will start to flash 500RPM before the RPM point you set, at which time it goes constant.
I have mine set at 6600, so that it starts to flash at 6100. During spirited driving around town I usually don't go above 6000RPM, so it hardly ever lights. It's a slight reminder to watch the fast revs during that top 600-900RPM in case I find myself running someone.
Old Oct 31, 2006 | 02:49 PM
mephistomyhero's Avatar
I guess that REV light is a reminder that we have the REV UP engine
Old Nov 1, 2006 | 12:27 PM
Imadriver's Avatar
OK, cool. I didn't know that. And on my '06 I had to push and hold the stem; when it started flashing I then had to repeatedly push the stem to cycle through the settings (at 100rpm intervals). I set mine to 7000.
But what about the yellow/orange light that says "REV"? What is that and how do I get rid of it?
Old Nov 1, 2006 | 02:12 PM
GT-Ron's Avatar
The '05 may have the same process to change it. I may not be remembering correctly.
As for the yellow REV light it can't be turned off but could probably be disconnected.
My thoughts on it's pressence are pretty simple: If it wasn't there, people would be wondering (more importantly, wasting dealer/manufacturer time and effort asking) why they were sometimes getting a flashing red light that would sometimes come on constantly for a moment. If the flashing light said REV, you wouldn't ever be able to read it while it's flashing. Therefore, you have the REV indicator light indicating where the red shift-light will appear.
I think most of the cars come with it set at 8000RPM to avoid confusion among potential buyers and new owners.
Old Nov 1, 2006 | 10:21 PM
Imadriver's Avatar
Oh, I get it now. So "REV" is just a label describing what the red light beneath it is.
That's annoying.
Thanks for the info!
wonderizm
Sep 24, 2015 03:09 AM
03sedang35
Aug 29, 2015 07:56 PM
derres
Aug 28, 2015 03:27 PM
fredthesnail
Aug 27, 2015 09:26 AM
G35Sask
Engine - Intake/Fuel
Aug 1, 2015 11:16 AM
