Rattling Sounds!!
Old Nov 15, 2006 | 04:43 AM
hungryhippo's Avatar
Rattling Sounds!!
So i turned on my car today and am hearing some weird rattling sounds.
If the clutch is depressed, the sound goes away.
I only get the sounds when I sit in idle that's when it's the worst, or when i'm just rolling in gear. When i'm accelerating I'm guessing it's just moving to fast for me to hear or feel a distinct rattling.
When I'm sitting in idle, I can feel every "rattle" through my stick. Anyone know what this is? My friend said i might have chipped off a tooth on one of my gears which might cause it. I guess I should get this fixed asap but what would happen if i just drive with it for another 300 miles or so?
THIS SUCKS!! But thanks for all your responses in advance.
Old Nov 15, 2006 | 08:06 AM
chilibowl's Avatar
Throw out bearing.
Old Nov 15, 2006 | 11:56 AM
The dealer said it's the bearing between our 2 discs in our 2 disc clutch system which is suppose to take stress off the tranny if you drop the clutch to suddenly at high RPMs. Does anyone have more knowledge about this?
So I'm guessing that bearing is called the throw out bearing as chilibowl said?
Is this normal? He said that they don't need to fix it and it will go away after awhile, is this true or should I be adamant about getting it fixed?
Old Nov 15, 2006 | 12:21 PM
binar's Avatar
The transmission is connected to the engine via the clutch. The throwout bearing isolates the release fork from rotating drive components. See here for more details. If my throwout bearing was making noise I would get it replaced. Depending on how many miles you have on your clutch I would replace the pressure plate and the clutch too. Most of your cost will be associated with pulling the transmission. Also, I don't know what they mean when they say 'two clutch'. Here is a pic from our service manual. Rattling Sounds!!-g35clutchassembly.jpg
I only see one clutch . I hope that it was just a misunderstanding.
Old Nov 15, 2006 | 12:44 PM
I only have 11K miles. The funny thing is a guy that brought his car in at the same time had the EXACT same problem. Sounded the same and everything... he had 8K miles...
Old Nov 15, 2006 | 12:52 PM
giddyup69's Avatar
he probably meant that it's a dual-mass fly-wheel. my '05 (and other's) displays the exact same symptoms. i've been told that it's normal, just like my clutch chatter. when i push down on my clutch pedal i also get small unusual feedback, similar to the feeling of pins-and-needles. it's just nissan quality at its finest.
Old Nov 15, 2006 | 12:58 PM
06Gee35's Avatar
I Make Your Car Glisten
I had the same sounds on my 2006 coupe with 3000 miles on it and the dealer replaced the whole tranny. Also my tranny started making a whining noise from 2000 rpm and up in 1st through 4th gear. The serive manager said the problem was the throw out rod assembly (which includes the bearing). Go to the dealer and have them check it out, you might get a new tranny out of it like I did.
Old Nov 15, 2006 | 01:44 PM
Doc_Yizz's Avatar
If you do a lot of stop and go driving, or if you are one of those who keeps the clutch depressed while idling at a red light, it will likely happen sooner than anyone else. It can happen at any mileage. However, the dealer should cover it. Insist on it or go to another dealer. I had mine changed at about 25,000 and will have it changed soon again...
Old Nov 15, 2006 | 01:51 PM
GreenGoblin's Avatar
The goblin resurrection
so this is def the throw out bearing
Old Nov 15, 2006 | 11:37 PM
anyone know what would happen if i drove with a busted throw out bearing for a while? they don't have any loaner cars till 5 days and I drive 100 miles a day to work
Old Nov 15, 2006 | 11:44 PM
d4vid's Avatar
i took my car in today for the same reason... but dealer ended up dropping a tool box on my door... so we'll see how it goes...
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
