What's up wheel gurus?!
Old Jan 26, 2007 | 11:30 AM
Dubfound's Avatar
Hello! What's up wheel gurus?! I have an opportunity to pick up a sweet set of staggered wheels! Here are the specs:
-19” 8.5” in the front 2”lip and 10” in the rear 3”lip.
-The front is 35mm and rear is 20mm offset.
1 Will these clear my Brembros? 2 What tire size? 3 Will they sit flush with my fenders?
Thanks a lot!!!
Old Jan 26, 2007 | 11:35 AM
k67p67's Avatar
+35 is better suited for a sedan. You'll need 10mm-15mm spacers to be flush with the fender. The rears should be pretty close. You may need 5mm spacers depending on how flush you want them to be.
Last edited by k67p67; Jan 26, 2007 at 11:48 AM. Reason: corrected recommended spacer size
Old Jan 26, 2007 | 11:42 AM
GreenGoblin's Avatar
The goblin resurrection
you will need about a 25 offset on the brembos the 20 in the rear will work but not out front
Old Jan 26, 2007 | 12:18 PM
papiloco21's Avatar
not necessarliy...i had a 19x8.5 +38 offset in front and it cleared brembos fine.
Old Jan 26, 2007 | 01:34 PM
Dubfound's Avatar
Good to know! The wheels are Iforged 3 piece if that matters? My buddy has treated them like gold!......
Old Jan 26, 2007 | 02:13 PM
papiloco21's Avatar
sweet....post pics when you get a chance
Old Jan 26, 2007 | 02:14 PM
Hi-TechG35's Avatar
+25 will clear the Brembos in the rear. I am running +25 all around with a spacer in the front.
Old Jan 26, 2007 | 02:32 PM
Dubfound's Avatar
I am an offset retard! The higher the MM the more the wheel sticks out? Correct?
Old Jan 26, 2007 | 02:41 PM
papiloco21's Avatar
nope, its the other way around
higher offset the less it sticks out, the lower it is the more it sticks out (more lip, wheel more flush with fenders)
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
