Help! Intermittent starting problems
Old 01-30-2007, 01:33 AM
cloud's Avatar
I have had this problem a couple of times before but recently it has become more frequent. Many times I turn the key but the engine doesn't start and when I try it the second time, it barely starts(meaning it feels like its about to stall then starts) any idea of what's wrong?? This is very annoying...I only have 13k on the odo and have been keeping up with maintenance.
Old 01-30-2007, 01:39 AM
JackD's Avatar
What year is your G? I have an 06 6mt with 8000 and it happened twice. Would not start on first try and had hard time on second.
Old 01-30-2007, 01:41 AM
cloud's Avatar
2005 6mt
Old 01-30-2007, 03:18 AM
Ashyknucklz's Avatar
Interesting ..... had this happen to me 2wice w/in the last 3 weeks. 04 6mt w 21k
Old 01-30-2007, 03:50 AM
bull3t's Avatar
if you drive your car hard...i suggest you clean the throttle body every 30k or so...before i cleaned my throttle body my car would start up, but the revs would
drop and almost stall (it actually stalled a few times)...after i cleaned it, it was good as new...
Old 01-30-2007, 03:52 AM
papiloco21's Avatar
maybe need to re-calibrate throttle body butterfly valve, i know it can cause a rough idle, this is if you ever did some mods thougth, had it happen to me....look on the motordyne website, on the last page of plenum spacer instructions.
just a guess
Old 01-30-2007, 04:57 AM
cloud's Avatar
how do you clean the throttle body? any DIYs?
Old 01-31-2007, 12:53 AM
cloud's Avatar
I did the throttle body repositioning & ecu reset and all that stuff. Nope didn't work. It happened again tonight.
BTW I scraped my flex joint earlier when my car was lower, could it be a vacuum leak causing this? It's not destroyed but the flex joints are sort of torn
Old 01-31-2007, 01:55 AM
papiloco21's Avatar
do you have a plenum spacer installed? maybe a bolt is loose?
check all hoses in engine bay.
also check battery if its dying perhaps?
Old 01-31-2007, 02:37 AM
cloud's Avatar
yes i do have a plenum spacer installed.
Old 01-31-2007, 02:53 AM
papiloco21's Avatar
make sure all bolts are tight, maybe ya got a leak, also check the rubber gasket near the oil cap, often tends to get stuck in spacer during install
Old 01-31-2007, 02:54 AM
papiloco21's Avatar
^ actually symptoms of that would prob be rough idle as opposed to starting issues, but its a try.
Old 01-31-2007, 03:16 AM
patrickwong's Avatar
Damn,
I thought i was the only one experiencing this problem. I have an 04 Auto with 57k and it's happened to me couple of times. It usually happens after i drive the car hard. The dealer has no idea what is causing it.
Old 01-31-2007, 03:34 AM
papiloco21's Avatar
any TSBs on it?
Old 01-31-2007, 05:14 AM
bull3t's Avatar
Originally Posted by patrickwong
Damn,
Try cleaning the Throttle Body...here is my DIY...if you don't want to read then just go to post #12...
https://g35driver.com/forums/g35-coupe-v35-2003-07/127892-throttle-body-experience.html
Quick Reply: Help! Intermittent starting problems
