sedan vs coupe
Old Nov 26, 2003 | 04:47 PM
2k2MaximaRIP's Avatar
sedan vs coupe
I tried posting this in the Midwest forum, but got no responce.
Are there any stock 6MT Coupes willing to go for a friendly drag with my stock 6MT sedan? Or dyno back to back with me? Auto's welcome too, but I'm trying for an apples to apples comparison.
I've heard that the 6MT sedan isn't too far off from the coupe in terms of power, and want to prove or disprove it.
Old Nov 26, 2003 | 04:55 PM
Re: sedan vs coupe
i forgot to mention, I'm in chicago
Old Nov 26, 2003 | 05:15 PM
DragonGcoupe's Avatar
Re: sedan vs coupe
You won't get a fair comparison, unless both the drivers are near the same skill.
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
Old Nov 26, 2003 | 07:10 PM
FDNameBrands's Avatar
Re: sedan vs coupe
Not unless they both race each other a few times, switch cars then do it again then average out the times for each car.
Old Nov 26, 2003 | 07:34 PM
BMW3toG35C's Avatar
Re: sedan vs coupe
Car & Driver tested the 6MT sedan at 0-60 in 5.9 seconds. In two separate tests of the 6MT coupe, they got 5.5 and 6.0. A pretty even call I'd say.
While the sedan has 20 less HP it probably makes up for most if not all of the difference with its lower weight.
Old Nov 26, 2003 | 08:13 PM
Re: sedan vs coupe
actually, the weight difference between the 6MT sedan and coupe isn't all that different... the reason I want to test is that I've heard of people coming up with comparable dyno numbers. In an Ideal world, I'de like to race and dyno against soeone on the same day. I could dyno myself, but you know how dynos are-hard to believe unless they're back to back. Any takers? I do believe the coupe is faster... I just want to know by how much, and how to remedy that problem!
Old Nov 26, 2003 | 08:57 PM
EZZ's Avatar
EZZ
Re: sedan vs coupe
Remedy...Two words...Twin Turbo
Old Nov 26, 2003 | 09:08 PM
Re: sedan vs coupe
Its kind of funny how the sports version has more weight heh.
Old Nov 26, 2003 | 09:09 PM
Re: sedan vs coupe
no no, three words: Solid Fuel Rocket
Old Nov 26, 2003 | 11:31 PM
liquidforce13's Avatar
Re: sedan vs coupe
First of all the Coupe is only 35 lbs more then the sedan, which if u take 10hp away for every 100lb;s then thats only 3.5 hp thats been lost so the coupe still has a 15.5 hp advantage over the sedan. Also If you want to see the difference between the coupe and the sedan, going by the rule of statistics, u cant get the true results until repetitive tries. U should race about 3-4 times and take the average and if both drivers have been driving there cars for a while and are decent drivers then the results should be pretty accurate.
2004 G35c Black on Black/ 6mt/ premium/ aero
Old Nov 27, 2003 | 12:13 AM
qirex99's Avatar
Re: sedan vs coupe
yawn
drivers race
Old Nov 27, 2003 | 12:20 AM
OvaYahead's Avatar
Re: sedan vs coupe
damn your in chi town. I would take you up on it if you were in cali. Anyone in the bay area up for the same match up?
BS G35C 6spd navi/aero/prem
Old Nov 27, 2003 | 01:07 AM
Re: sedan vs coupe
Yea, juss saying .. Usually sports versions are lighter, heh.
Old Nov 27, 2003 | 04:43 AM
Re: sedan vs coupe
drivers race... which is why a dyno would be good. Also, four drags could even things out a bit. Each could do two in thier own car, and two in the others car. That would point out who the better driver was, and you could sort of adjust for it...
teamghost
Jul 28, 2015 04:52 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
mushu
Jul 15, 2015 03:55 PM
