y are the coupes so damn heavy??
Old Apr 16, 2007 | 08:59 AM
  #106
06obg35coupe's Avatar
Originally Posted by adrenaline rush
I had my G corner weighted today and it came out to 3390 lbs. That's with no spare and just over a half tank of gas. It's an 03 6 speed without nav or aero. I think with some lighter wheels, less gas, a lighter exhaust system, you could bring it down to 3300.
I'm back to this thread because this fellow member has something positive to say.
That's not bad. I believe '03-'04 G coupes' base weight is 3435lbs. Yes, gas weights a lot. If you had 1/8 of a gas in the tank you'll shave another 40-50lbs.
Most definitely you can get it down to 3300lbs. Your G now weighs slightly above a Z. Actually, it probably weighs about the same as a touring Z.
I considered a RX-8 and a S2000 before I bought my G. Correct me if I'm wrong, but each one weighs around 3000-3100lbs depending on how many options you have on it.
Stock for stock, handling is better on the S2000. However performance is the same because on MT,RoadandTrack, and CarandDriver, 0-60 for a G and S2000 is 5.7-6.0 . It's definitely a drivers race.
However due to its unique design, rear seat, and exhaust note buying a G was an easy decision.
TWASkyliner
Feb 8, 2020 08:00 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
bjo16
Aug 4, 2015 09:52 AM
itschuckster
Jul 25, 2015 08:07 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
