ECU upgrade questions...?
Old Feb 16, 2007 | 10:14 PM
sahib's Avatar
hey guyz, i've been doing some research but i havent found any solid numbers. for those of you that have done ecu upgrades, how much HP did you gain? how much did it cost? and exactly what did you do?
-thnx
Old Feb 16, 2007 | 10:32 PM
TheTrance's Avatar
what mods have you got?
Old Feb 17, 2007 | 01:26 AM
sahib's Avatar
none as of yet, i dont have one...i'm just doing some research, i pick up my g in may, this is for a friend, he has test pipes and a spacer...thats it.
Old Feb 17, 2007 | 01:41 AM
gary c's Avatar
Questions....................
Unless you've made some major mods doing anything with the ECU is
worthless. You'd need all my mods plus headers and hi-flow cats or test
pipes to need an ECU reflash. Even then I'm not sure how much H.P.
that would pickup.
Old Feb 17, 2007 | 02:05 AM
sahib's Avatar
^thnx...i heard from someone that an ECU tune can give you a HP boost...kinda like the M3's dinan ECU upgrade...guess not...
Old Feb 21, 2007 | 02:42 PM
fortified's Avatar
You may get some improvement even stock, or minor intake mods like plenum (about the max).
Once you get into the exhaust is when things start to break loose (in a good way) and when you want an ECU tune to get your A/F ratio in line and a good ignition curve as well as raising the RPM limit and having the throttle go full open at WOT.
So a small gain for the same amount of money for a reflash, against a major gain with the other right stuff done to the car.
Old Feb 21, 2007 | 02:52 PM
BadBoy06's Avatar
I think this would apply to pre 05's-06's
Old Feb 21, 2007 | 03:15 PM
b00stedjustin's Avatar
these are completely different. The DINAN ecu upgrade is a chip, a reflash is completely different.
Old Feb 22, 2007 | 12:09 AM
fortified's Avatar
Good, because that's what I have planned for my 04!
Old Feb 22, 2007 | 12:11 AM
Skaterbasist's Avatar
Retired SuperMod
Only reflash if you have enough mods.
Then you'll feel your G awaken
Old Feb 22, 2007 | 12:34 AM
cochinogato's Avatar
so just curious myself- sorry for the thread jack- but ecu reflash? or the utec?? i thought about the utec myself but wasn't sure if it was worth it
Old Feb 22, 2007 | 01:33 AM
sahib's Avatar
its a 04 so no worries. yea i was thinking that after getting all the mods one can upgrade the ecu to kind of "bind" the mods so they work together to produce some good results...
^no worries abt the thread jack...hehehe
Old Feb 22, 2007 | 09:20 AM
FAST1's Avatar
It's a waste of money for the G. An ECU reflash or a new chip is great for turbocharged cars, since they will increase the boost. For example the GTR will be a great candidate for a chip. From the factory the boost will only be 10 psi and even that will produce around 450HP. The chip will increase that to well ove 500HP by increasing the boost significantly.
Old Feb 22, 2007 | 06:12 PM
fortified's Avatar
Granted a reflash etc, is essential for turbo or SC cars. But anytime you change the A/F ratio and tend to drive hard it is wise to have ECU programmed.
You can't argue with the success others have had, including the dyno numbers as well as better drivability for those with extensive exhaust mods.
KruZZe
Feb 27, 2023 05:04 PM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
