Air Filter Swop
Old Mar 3, 2007 | 04:37 PM
uk350gt's Avatar
Air Filter Swop
I want to put in a K&N Filter. I've searched for guidance on how to get into the air box to put it in, but nothing found. The manual instructs the reader to take the air box off, is this necessary?
Thanks
Old Mar 3, 2007 | 05:07 PM
BadBoy06's Avatar
what I did was unlock the clips even that lower
PITA 1. Then its cake
Old Mar 3, 2007 | 05:12 PM
fhumphrey04's Avatar
There are clips all around your airbox, you need to undo the two top and then reach down to undo the two lower ones. You might have to take out the screw on the right side of the airbox, but Im not sure.
I installed mine when I did the z tube so it was easy, so good luck!
Old Mar 3, 2007 | 05:15 PM
uk350gt's Avatar
Great, the two top clips and one on the right hand side as you look at it? Sounds pretty easy, even for me!! Thanks a lot.
Old Mar 3, 2007 | 05:20 PM
uk350gt's Avatar
I have purchase Z-Tube and this filter too but thought I do it one step at a time; this will be the first mod I do myself and I'm a little worried as I know nothing about engines, only what I have learnt on this forum. OK, so best to do at same time as Z-Tube then??
Thanks
Old Mar 3, 2007 | 06:10 PM
Here you go
http://www.6mt.net/mod-g35-350z-intake.php
complete guide to installing the ztube, when you have the original intake off you should put your filter in as it is convienient. It took me 15-20 minutes
edit: we have the same color car by the way
Old Mar 3, 2007 | 06:13 PM
BadBoy06's Avatar
Thanks
no need to worry.. Its quick and easy. when you take the intake off.
make sure when you put the Z tube on the seal is tight around the clamps.
should take you 20-30 mins tops
Old Mar 3, 2007 | 06:40 PM
uk350gt's Avatar
Great advice and guidance information. Thanks very much.
Old Mar 3, 2007 | 06:46 PM
uk350gt's Avatar
Here you go
Cool. I love the colour. I get lots of compliments on the colour over here
KruZZe
Feb 27, 2023 05:04 PM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
