I tried 100 octane fuel today and ...
Old Jan 18, 2004 | 03:25 AM
GXXXV's Avatar
well, I finally decided to try 100 octane performance gas today and after paying $4.23 per gallon I can honestly say that it is not worth the money. I could not tell any difference at all....
I only tried 7 gallons and my tank was almost empty.
Old Jan 18, 2004 | 03:44 AM
BMW3toG35C's Avatar
Re: I tried 100 octane fuel today and ...
It just occurred to me that given the higher combustion temperature of higher octane gas, it's possible it might be slightly better in very hot climates. I don't know what the weather's like where you are (obviously it's quite cold in much of the US right now), but you might want to try it again just for the heck of it on a hot summer day. It might still make no difference, but if it was ever going to, it would probably be then.
Old Jan 18, 2004 | 01:34 PM
Gordgee's Avatar
Administrator
Using a higher octane gas likely wouldn't result in a performance increase unless you have mods and the ECU was reset to take advantage of the higher octane.
<font color=green>GroundingGear™ Equipped </font color=green>
Old Jan 18, 2004 | 08:15 PM
AirSplat's Avatar
That's exactly right. Unless you can actually utilize the higher octane, it's not really going to make a differene. If you had FI, then the higher octane would make a muc more noticeable difference. In fact if you had a turbo and was boosting really high, then you wuold definitively notice the difference.
'04 G35 6MT Ivory Pearl
K&N Drop In / Stillen Grounding Kit
Borla Headers/Dual Cat-Back Exhaust
Nismo Front Bumper/Side Skirts
Impul Rear Bumper/Spoiler
AirSplat.com for AirSoft Guns!
Old Jan 18, 2004 | 08:47 PM
AirSplat's Avatar
Here's an article about high octane fuel.
http://www.motorcycle.com/mo/mcnuts/rt-fuel1.html
Old Jan 18, 2004 | 09:56 PM
JustinP10's Avatar
Higher octane fuel can actually decrease power slightly, if it's not needed. If you're boosting then higher octane fuel will allow you to run more boost before any detonation may happen, but on most N/A applications (other than ones with very high compression or other major work) running the lowest octane that doesn't ping/knock will result in the most power. It may not be enough to measure, but it's supposed to burn better. I can't remember all the little details, but I'm sure there's a lot of articles about it on the net.
Justin McClanahan
Heavily Modified 95 Infiniti G20
Working on a G35 Project Coupe
http://www.EverythingG35.com
Old Jan 19, 2004 | 01:23 AM
Ehren's Avatar
The most amuzing thing on this post is $4.23 a gallon. Gessh. Aviation Gas is half that and 100LL
Old Jan 19, 2004 | 02:38 AM
gdupg35's Avatar
I did the same thing this week, and it was $3.95 a gallon at 76 in Las Vegas. I put in about 5 gallons on a nearly empty tank. It did feel slightly smoother, but forget about it at that price!
Old Jan 19, 2004 | 03:10 PM
tpware's Avatar
I've heard 100LL av gas will toast your rings..
bs g35c lth/prem
Old Jan 19, 2004 | 03:26 PM
Ehren's Avatar
I've heard this as well. but I figured it would be the same for 100 octane at the pump. Not completly sure of the difference. They are both 100 octane low lead. I've seen guys buying the stuff at airports before in gas cans. Perhaps they have some souped up lawnmowers and weedwackers.
Old Jan 19, 2004 | 06:53 PM
JustinP10's Avatar
Airplane fuel has deicing agents in it that aren't designed for automotive use. That fuel also is meant to be run at a certain rpm, rather than all over the rpm range, like in an automobile. It'll still work, but it's not the same as a normal high octane automotive fuel.
Justin McClanahan
Old Jan 19, 2004 | 06:58 PM
Carlos3186's Avatar
what about octane boost? i understand that our ECU are desighned for a certon octane and wont give us performance boost but what do all think about it on F/I engines and such is it a gimic or does it really boost ur octane?
<a href="mailto:Carlos3186@hotmail....otmail.com</a>
Old Jan 19, 2004 | 07:01 PM
JustinP10's Avatar
The change is so small it doesn't do much at all. a single bottle in a full tank may raise your octane rating from like 90 (say you got a bad tank of 91 octane) to 90.5-91.0. Other options would be something like a gallon of toulene mixed in with a tank of gas at lower ratios. Toulene has a rather high octane rating (114-117 IIRC?) and can be purchased by the gallon at many hardware stores in the paint thinner section. I wouldn't recommend this, but just saying it's out there...
Justin McClanahan
Old Jan 19, 2004 | 08:37 PM
GurgenPB's Avatar
People - DO NOT put avgas in your car. LL stands for Low Lead (as I am sure many of us know), and hte lead will KILL your sensors FAST.
I am also a pilot, and this is the gas that we use in the piston engines. The 100LL or 100 (full lead content that can be found in Mexico) fuel also has gas scavengers which, if I am not misaken, work at above 360 degrees F cylinder head temps (CHTs) and below a certain cutoff (like 460, I am not sure here). The piston airplanes (almost all of them) have a redline of 2500-2700 rpm. The conceivably higher temps achived in a car at higher rpms may, and probably will, cause higher temps, and thus no lead scavenging. lead scavenging or not, the lead WILL damage your sensors. So NOT use it.
gurgen
Mhacker
Sep 12, 2015 07:35 PM
Rhinos7777
Sep 6, 2015 05:36 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
