Headlamp Removal for Projectors???
Old Feb 1, 2004 | 09:17 PM
Aznteazer's Avatar
Re: Headlamp Removal for Projectors???
wouldn't that ruin the whole geometry of the headlamp?
if not, i wanna do one too.
Coupe 6-spd Twilight Blue/Black Premium
Old Feb 1, 2004 | 11:20 PM
joenismo's Avatar
First you need to remove the front bumper. I think there are 6 clips along the top, two screws going upward where the bumper meets the fender, and about 12 10mm bolts along the bottom. Then there are 4 10mm bolts holding the headlights in. One on the top and three around the bottom of the headlight. Then unplug the headlight, the connector is on the bottom of the headlight. This whole process is pretty easy, the hardest part is the two screws going into the fender. Either remove the fender liners or push them out of the way.
Old Feb 1, 2004 | 11:32 PM
ReDRoK8's Avatar
If you are lookin for pointers maybe you could PM E_K. He did what appears to be a great job using X5 projectors. I think would have tried for a smaller lense for the projector. This project is something I've also wanted to tackle but after E_K said it took him approx 20 hours I hesitated. Try checking the link below for pix and more info. Peace.
https://g35driver.com/forums/showfla...sed&sb=3&part=
-Jason
Laser Red '03 6MT
Old Feb 2, 2004 | 12:14 AM
docmassage's Avatar
If you do it be sure to post some pics!
Old Feb 2, 2004 | 12:15 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Make sure that they know how to take the bumper off. I've learned the hard way that outside places don't always know the proper way to take off a bumper. They'll use brute force if they can't figure out what screw is left. Just my experience.
What kind of projectors are you going with? The G35 headlamp has a few considerations such as available space in the low beam area, so that you can't just pop any projector in there.
$700 is a lot, but if you are paying someone to do it, I guess it's an ok price.
Old Feb 2, 2004 | 01:11 AM
ReDRoK8's Avatar
What about the 350z projectors or the S2000? Those are pretty smallish. I feel the same way that if the projector is too large it will ruin the look of the housing. Wouldn't the 350z projectors maybe work better becuase they are both Nissan? Just an idea....
-Jason
Laser Red '03 6MT
Old Feb 2, 2004 | 01:38 AM
E_K's Avatar
E_K
350z projector will not work. The beam is created with the combination of a small projector AND the reflector. You would have to get both components in. And even then, your cutoff line won't be as razor sharp as a true projector unit. I heard it's about as good as an E-code reflector.
S2000 is good, but it's hard to find. And the pre2004 S2000 units were integrated into the headlight frame.
A larger projector in general is brighter. E-codes give more foreground light with more prominent prism effect. You want the beam to clear the chrome bezel between the high and low beams. You don't want the projector to be so long that you can't close the bulb cap at the end. You don't want the projector to hit the outer headlight cover. It's not as easy as it sounds. Most people like 90mm Hellas, A6, or S2000 projector. The Q45 is nice, but it's rare, and I don't think it will physically fit. I would opt for the biggest projector that can physically fit. If you want a tiny projector, I'm not sure why one would go through that amount of trouble for a beam that might be weaker than stock. There's a whole world out there when it comes to projector retrofitting. But the end result is worth it.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
