Steering Wheel Shakes, HELP!!
Old Oct 11, 2007 | 01:57 PM
sevret.t's Avatar
I have a 2004 G35 Coupe, i was driving home from getting some mickie d's about 2 weeks ago and on the way home my steering would act up when i pressed brakes so i figured my tire was a little bit low, turns out it was almost fully deflated, so i filled it back up with air, every since then my car has had an alignment problem and the steering wheel starts to vibrate and shake from about 65mph up, anything under that i cant feel any wheel shake but i still have alignment problems.. anyone know what could be the problem im gonna have my car aligned tomorrow but is there anything else that could be a problem? i am getting new wheels/tires this weekend so hopefully that and the alignment will take care of it, the tires are almost brand new, about 85-90% tread life.. please help, thanks in advance guys
Old Oct 11, 2007 | 02:10 PM
edindaclub's Avatar
maybe its becuz u got bigger size of wheels?
Old Oct 11, 2007 | 02:16 PM
Gilley's Avatar
Get the tires balanced.
Old Oct 11, 2007 | 02:43 PM
bocatrip's Avatar
Over 50 MPH steering wheel shake=wheel balance
Steering wheel shudder upon braking=rotors with excessive runout or other rotor problem.
Old Oct 11, 2007 | 02:47 PM
Alan's Avatar
dont eat mcdonalds.
Old Oct 11, 2007 | 05:19 PM
I Z Boss's Avatar
Ok, normally when the steering wheel shakes while braking it's the rotors....warped rotors, if you don't have Brembros get them turned and you'll be good. A shudder on stop is rotors, a shudder on acceleration is tire balance.
Old Oct 11, 2007 | 09:34 PM
fabulustt7's Avatar
i had the same problem...apparently what happens when your tire is really low and you drive on it maybe even a few miles, the rim begins to turn on the inside of the tire, eating away at the sidewall. When you refill the tire with air, sometimes little air pockets form where the tire meets the rim. everytime your wheel rotates you feel the air pocket slightly, but it isn't signifacant enough to shake the steering wheel until higher speeds such as 65mph in your case. I dont know if their is any solution other than buying a new tire. my case was so bad that the shop told me i had to. i have 20inch wheels though. i dont know whta your setup is
Old Oct 11, 2007 | 09:58 PM
gary c's Avatar
Steering wheels issues....!
From what you described when the tire in question went down you probably
threw off some of the wheel weights. Since you're getting new wheels and
tires just have your alignment checked.....you're home free (well almost)!
With the new tires/rims you shouldn't have any high/low speed vibration.
If, when you press the brake pedal you have steering wheels shake it's
due to the disc's being warped......hopefully this won't occur.
Old Oct 13, 2007 | 12:14 AM
sevret.t's Avatar
im just gonna buy new tires, my car is completely stock right now, i dont think im gonna buy new wheels anymore, i wanna get out of the import scene, im lookin for a 05^ gto.. x.x
Old Oct 14, 2007 | 08:24 PM
ElixXxeR's Avatar
Could be warped rotors, or you need your wheels balanced or an alignment. You stated that it occurs when braking, which makes me think it's probably rotors with a possibility of wheel balance.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
rping
Jul 26, 2015 09:53 PM
Karnicle
Jul 23, 2015 05:08 AM
