Gas Mileage- 374 Miles a tank!
Old Jun 28, 2008 | 11:59 PM
  #31
Tom_G35C's Avatar
Is there a consensus that the tiptronic gets better gas mileage?
In M4 and M5 gears, the tiptronic doesn't lock up completely. However in Drive, the 4th and 5th do lock up completely, which saves gas. Carefully try switching from D to M5 on the highway and the revs go up about 5%. On a long highway drive, Drive would use less gas than M5.
The tiptronic could save gas in the city because you can choose your shift points.
I calculate my gas mileage on every tank. I am always in Drive. I don't notice any gas mileage difference if I drive conservative or aggressive. The biggest impact is when I am stuck in traffic, the mileage stinks. When I am on the highway, it is 20 mpg or more.
Old Jun 29, 2008 | 12:09 AM
  #32
tran03's Avatar
Originally Posted by stradaONE8
It worked beautifully and I got to 29.5mpg until I got near Cleveland where the city driving dropped it to 29.2...but not bad for a highway trip.
Finally I tend to get around 400-420 a tank with mostly highway and around 350-375 otherwise with more city for about 16-17gal...granted I don't drive around like I stole it most of the time...thats my 0.02 for those of you who want to save gas.
400-420 highway and 350-375 city seems to be what others are getting.
Your ~29MPG, was that figured by your navigation or what you calculated when you filled up your tank?
If you got ~29MPG and filled up when the fuel light hits, the full refill at that point should be right at ~16.5 gallons, which would equate to ~480 miles a tank.
Just wanting clarification, was that how many miles you got out of 16.5 gallons (a full tank when the light comes on, give or take 10-15 miles) and your particular driving method?
Old Jun 29, 2008 | 12:46 AM
  #33
2K6G35c's Avatar
Just filled up today and, I'm getting right at 23MPG on my 2K6 coupe. I drive conservatively but, floor it every now and then. I rarely drive it and it has less than 10K on it, not sure if that has anything to do with the mileage. I mostly drive my other car, a 2K MAX SE, it has a 3.0 and even that used to give me 22-24 MPG when it was new, now that old car gives me 20MPG. These engines are fuel efficient even in hot weather, seems that it's peoples driving habits that get them in trouble.
Old Jun 29, 2008 | 04:38 PM
  #34
familyman333's Avatar
I do a lot of hwy driving for work and typically get around 430 miles on a tank. I usually drive speed limit +10 so I am not being that conservative. By my calculations I am averaging 25 mpg overall on 93 octane.
Old Jun 29, 2008 | 07:14 PM
  #35
stradaONE8's Avatar
The 29.5 was just for the trip itself, from Columbus to Cleveland as calculated by my nav, I couldn't actually refill/test it out becauase the first 60 miles on the tank was city. T
here was some spirited driving in Cleveland as well and I averaged 28.5 on the way back to Columbus. So that's why I didn't get 29 for the whole tank. I believe whole tank was 25.5 or 26 mpg...I forget the exact number, so mostly highway probably a bit over 325 mi, and the rest was city, some was spirited.
I figured it was pretty accurate because even with the 100 or so mi of city driving, I managed near 26mpg.
Blakearold
Aug 19, 2015 10:20 AM
Jroc2017
Aug 16, 2015 07:16 PM
Jroc2017
Aug 12, 2015 11:21 AM
joedaddy1
Jul 28, 2015 02:58 PM
