My Alarm Key Holder not working* help!
Old Sep 8, 2008 | 12:05 PM
cochinogato's Avatar
tired to search around but couldn't find any info on this, i have an '05 G, and for some odd reason all the buttons for the car's alarm do not work at all, from the Locking of the car, unlocking, opening the truck and the panic button have all just died- thought maybe it could just be the battery since i just use one of these as my main and i have the other as my spare, but when i got my spare one, same thing... they all don't work, so now i'm just confused? i can't arm my car at all and now i have to unlock the car with the key, anybody have an idea on how i can get them working again?
Old Sep 8, 2008 | 01:53 PM
TopTech's Avatar
Try a new battery before doing anything else.
Old Sep 8, 2008 | 09:51 PM
still no luck- changed batteries on both key fobs and they both seem to be just dead out of no where, any other suggestions?
Old Sep 11, 2008 | 03:54 PM
no hope still, checked the car's manual and there isn't anything in there about alarm keyfob, it only says about changing batteries, what's odd is that the red light in my car to indicate the alarm is working blinks, but the keyfobs themselves don't work at all- not sure if i should buy another set of batteries or not :/
Old Sep 13, 2008 | 05:40 PM
r.drifter's Avatar
i had the same problem on my driver side. Its nothing due to the battery. Its the motor worn out. i forgot what it call. I brought to the dealer. They said they fix it for $450. Then i bring it to the bodyshop. The motor is only around $80. So i will fix it in the bodyshop when i had time.
Old Oct 14, 2008 | 01:10 AM
klg35's Avatar
have exact same problem as o/p and went through the changing of the battery route....
did the bodyshop fix/replace that 80dollar motor you're referring to? if so, details!!
Old Oct 14, 2008 | 09:07 AM
scottsg35's Avatar
https://g35driver.com/forums/faq-diy...r-key-fob.html
try reprogramming it with the instructions on this link. If that doesnt work, your reciever could have gone bad. I dont believe it has anything to do with a door lock actuator, since it affects both doors, and the trunk.
Old Oct 14, 2008 | 10:37 AM
azng45's Avatar
wat the hell body shop have to do with Alarm?
Old Oct 14, 2008 | 06:20 PM
klg35's Avatar
thanks, will try that tonight.....now gotta find the remote.
Dallsinghjr1
Sep 17, 2023 11:25 AM
cpmiller22
Oct 10, 2018 10:54 AM
g.spot
May 9, 2016 10:54 PM
G35xdriver04
Nov 7, 2015 08:31 PM
