rad fans not working
i did a search but did not come up with any solutions.
i took my g35 out today and while waiting in a "drive up" fast food rest., my G started to over heat and spew rad fluid.
i got it home safely and looked for a bad fuse which controls the fans. the 40A fuse ohms out "good".
what else could be the source of why the fans are not working? i sure would appreciate the help.
thanks in advance!
thanks in advance!
Originally Posted by badtziscool
I thought the relays for the fans were also in the fuse box next to the battery. I don't have the manual, so I can't confirm. When you turn on your a/c, does the other fan come on like it's supposed to?
just came in from switching the wiring connections from the 2 fans. the fan to the left does not come on. i suspect a bad fan motor(?). i guess i'll have to take it to my infiniti dealer to have it serviced. something i dread doing.
still can't find the fan relay's. anyone know what the cost of replacement is with the fan set-up? thinking i can get away from visiting my dealer, which is 40 miles away and i always get my car back with a "new" scratch
Originally Posted by ttrank
Fan relays are behind the battery:
i've already ordered a new set of fans. will have them next week. even though the car is under warranty, i'd rather not take it in for this. my local infinti dealer lacks professionalism. if it was a engine or drivetrain issue than yes.
have a great day
fan relay is behind the battery? do I have to remove the battery in order to see them? my radiator fans keep turns on until I turn off the engine. Normally, it should be turns on when the engine is hot and stop....in my case, these fans keep running....should it be relay? I saw in the manual about these relays but couldn't to find them....please help, I really appreciate it.
pd
pd
