wtf is wrong with my car?
Old Nov 20, 2008 | 09:17 AM
Symantec's Avatar
Question wtf is wrong with my car?
Hello everyone
I have an 03 g35 6mt
This weekend my car started acting crazy and I have no clue what it could be.
if I turn the car off during the day every thing is fine.
if I turn the car off at night (auto headlights on) the headlights turn off but the parking lights do not, then the fan turns on.
if I put my key back it and turn it to on (but not start) every thing stops and it acts like it should
the lights never turn off but the fan will stop for about 30 sec every 5 min.
and if I turn the switch for the lights to off as soon as I take the key out they turn back on and the fan starts aging
this is making me crazy I have know idea what it could be
for the mean time I have been just pulling the neg off the battery.
if its night time and i hook up the batt. it does the same thing.
hook up the batt in the day every thing is fine.
I already tried resting the computer
please help
thanks
Chad
ps. if I didnt post this in the right spot I would like to aploigize in advance.
Old Nov 20, 2008 | 10:03 AM
RunLevelZero's Avatar
I am totally guessing but it almost sounds like the sensor on the mirror which detects day or night is not working properly. I don't think it's your ignition and I hope it's not. The mirror is expensive but the ignition I believe is even more plus the install. Good luck and hope it's nothing serious. I would get it to Infiniti or your mechanic ASAP though. I'm not sure where you are but it's getting cold and it would suck to have a dead battery.
Old Nov 20, 2008 | 10:37 AM
Symantec's Avatar
what mirror? not the one rear view mirror?
where is that sensor i always thought it was in the dash.
i first thought it was the sensor but why is it turning on the fan. (not sure if its the rad fan or the ac, didn't look at it that close)
its completely unrelated systems.
on the plus side i have an extended warranty so I think im going to take it to Infiniti.
this isn't my daily driver so its not that big of a deal.
Old Nov 20, 2008 | 11:07 AM
vhtran's Avatar
^^^ Same here, first thing came up my mind is the sensor on the dash. You can see them under the windshield, that sensor probably need to replace. If you want to know, since its day time. Get a card board cover the sensors see if it will do the same.
Old Nov 20, 2008 | 12:00 PM
Symantec's Avatar
i understand what your saying but the sensor works fine when the car is on "i turn the key to on"
it only go crazy when the car is in "sleep" mode. but only if the sensor was reporting dark b4 the sleep mode
im dropping it off at infiniti tonight ill see what they say
Old Nov 20, 2008 | 12:14 PM
vhtran's Avatar
Sensor can make things crazy like that, because it may acts as a shortage. Anyway, keep us posted after being checked out. I want to know the issue as well.
Old Nov 20, 2008 | 03:49 PM
breftayka's Avatar
My G did the same thing last month, but only once. It drained the battery but left the right headlight on and the left side marker (weird). I shut it off and jumped it and it hasn't repeated...
Old Nov 20, 2008 | 04:50 PM
xXHotelCrazyXx's Avatar
Hmm def a weird issue. Have you done an ECU reset? How long did you leave the battery disconnected for? I would leave it disconnected for 10 minutes.
Old Nov 20, 2008 | 05:28 PM
Symantec's Avatar
I disconnected the battery for about 50hrs it was fine for the day then next night same thing.
the kicker is im going to bring it to the dealer tonight and the thing works fine. so i dont know if they will be able to tell me whats wrong
Old Nov 24, 2008 | 01:26 PM
breftayka's Avatar
How'd it go?
Old Nov 24, 2008 | 01:34 PM
blaccG35's Avatar
thats weird...my buddy got the same thing going on with his G(03) and at night time his tail-lights doesnt shut off but when you open the trunk all the way the tails go off but close it the tails come back on...he just d/c the battery every night its a PITA
Old Nov 25, 2008 | 09:05 AM
Symantec's Avatar
after a day and a half in the shop they finally found out it was the computer that controls the fuse box, the part should be in today and i should be able to pick the car up tonight. ill let you know the name to the part when i pick it up.
all was covered under my extended warranty and i got to drive around in a sick loner all weekend (08 g35x)
Old Nov 25, 2008 | 09:26 AM
GreenGoblin's Avatar
The goblin resurrection
glad they got it all figured out for you
Xfactor
Dec 1, 2019 12:52 PM
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
ClwMike
Jul 23, 2015 12:55 PM
