Headlight bulb question
Old Nov 23, 2008 | 11:01 PM
Mr. G35's Avatar
Hey guys, wondering if you can help me out. I've been on Sylvania's website to look for the bulb that sits on the outer side of the headlight. I am unable to find the size or bulb number. When you have the parking lights on, I am referring to the bulb that lights the strip on the side of the headlight. I'm not sure the proper name for it, whether it be city lights or what (on my 04 coupe). I would like to replace the bulb with an LED in each headlight. Curious as to whether someone can give me the bulb number, or the LED bulb number that I can replace it with? I could always take my wheel and liner in the wheel well off to get to the bulb, but I thought i'd turn to you guys first. Thanks
Old Nov 24, 2008 | 12:18 AM
emorehs's Avatar
Old Nov 24, 2008 | 01:30 AM
03g35vt's Avatar
They're T10 LED bulbs. Best bet to replace them is to just reach behind the headlight assembly. You might have to take out a few bolts on the headlight assembly to get to them. Would recommend using some gloves because it is very hard to get to them and quite uncomfortable but in my opinion much easier than taking the wheel well out and going through all of that. I've switched them out twice this way. Let me know if you got any questions
Old Nov 24, 2008 | 01:08 PM
Mr. G35's Avatar
Originally Posted by emorehs
Yea thanks, you were a lot of help. I performed a search and found nothing before I posted. I'm not new to these forums either, I was a member of VWvortex for 5 years. Maybe you could use some of your own advice
Old Nov 24, 2008 | 01:10 PM
Mr. G35's Avatar
hey 03g....thanks for the help, I'm going to try that. I will let you know how it goes. I didn't think it was possible to get to the bulb without going through the hassle of taking the wheel off. I will hopefully have pics soon. Thanks again.
Old Nov 24, 2008 | 07:30 PM
emorehs's Avatar
Mr. just trying to give something hint.. 194/168 bulb or wedge bulb what they called it.. I just changed mine, so don't even remove your wheels,, just jack it and remove the inner fender and they're you are....ready to change the bulbs..
Old Nov 24, 2008 | 09:06 PM
22inchg35's Avatar
also they are called "parking lamps" just replaced both of mine
Old Nov 24, 2008 | 10:32 PM
ollie23's Avatar
https://g35driver.com/forums/lightin...ent-guide.html
Here you go.
Old Nov 24, 2008 | 11:35 PM
Darkstar752's Avatar
That strip is called the Clearance strip. At least that's what everyone calls it on the forums. And you can do it without removing the wheel well, but it can be hard.
Old Nov 24, 2008 | 11:39 PM
Mr. G35's Avatar
Thanks a lot guys, I appreciate the help!
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EasySausage
Jul 20, 2015 03:56 PM
attarday
Jul 15, 2015 04:03 PM
