Problems Getting Gas Into The Coupe??
Old Jun 4, 2004 | 03:52 PM
DiamondG's Avatar
Re: Problems Getting Gas Into The Coupe??
It's a known problem and your dealer should know it. It's in the TSB list. I had the same problem and had it fixed. No problems since.
99 Supercharged Civic Si sold
03.5 DG 6MT Coupe
AIM: Ken99Si
Old Jun 4, 2004 | 04:10 PM
gto2050's Avatar
Unfortunately, I am not from Jersey. It was meant as a joke. If it offends fellow Jersey residents, I will change it.
Old Jun 4, 2004 | 05:03 PM
bsoo's Avatar
It's the nozzle
I remember once pulling into a gas station with a nearly empty tank, and the nozzle would click & stop almost immediately after I started pumping. After a few more futile tries, I simply drove up to the next pump and everything went fine.
I think what's happening here is that our gas tank receptacle may have been built such that it has a lower tolerance of variance in gas nozzles. Maybe a slightly-out-of-spec nozzle/pump (incorrect pressure, etc) that works just fine on most cars doesn't on ours.
One thing to remember is that gasoline is very volatile (i.e. splashes easily), and to my understanding that's what the auto-stop mechanism works with - splashbacks. So it's not hard to imagine this may all be a tolerance issue.
It's like a scratched up CD not playable in an ordinary CD player can play just fine in a $2000 player (stronger laser, better pickup mechanism, etc).
http://www.imagestation.com/member/?name=bsoo
2004 Coupe 6MT fully loaded incl. side moldings and splash guards, but no satellite radio.
Old Jun 4, 2004 | 05:38 PM
gsg's Avatar
gsg
What TSB# is it and what do they fix???
Old Jun 4, 2004 | 07:33 PM
DaBaur's Avatar
I'm with gsg: a LOT of us are having this problem and Infinity needs to address the issue. I do a lot of long-distance driving here in Texas and sometimes you're 300 miles to the next gas station. It's all I need to be stuck in a podunk town with 300 miles to go and I can't get more than 6 gallons into my tank. If someone knows the TSB then please share it so I can show it to my dealer.
Old Jun 4, 2004 | 09:58 PM
DED's Avatar
DED
It has happened to me. There is no known fix. There is no trick to get the rest in. It happens. Read somewhere it is due to the tank "double bladder" design.
I usually forget about it as soon as the hot air coming out of the vents starts to melt my thoughts.............
2004 G35C 6MT Black. Killer.
Old Jun 4, 2004 | 11:41 PM
DiamondG's Avatar
I don't remember what the TSB# is, but you don't need it. Just tell your dealer what's wrong and they'll fix it. Sorry I lost my receipt so I can't tell you what they replaced. I went to Metro Infiniti in Monrovia if any of you are So Cali folks.
03.5 DG 6MT Coupe
AIM: Ken99Si
Blakearold
Aug 19, 2015 10:20 AM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
attarday
Jul 15, 2015 04:03 PM
