After lowering I noticed...
Old Jan 29, 2009 | 12:40 AM
nchima's Avatar
After speeds of 65+ I get a lot of rattling, and it seems unstable, compared to OEM. I'm dropped on Tein S-Tech for 350z, and have tockico shocks; and a rear camber kit. I have 285/35/19's in the rear and had my fenders rolled. The rattle seems like it is coming from the rear. I had the alignment done, but I just don't know what the problem is...go figure.
If I went back to my old setup of 275's in the rear, would that cure anything? Someone let me know.
Thanks
Old Jan 29, 2009 | 11:50 AM
Corrosive's Avatar
Not too sure... I am picking up some S-tech's too so hopefully someone will chime in.
Could your camber kit be adjusted wrong?
Old Jan 29, 2009 | 12:19 PM
LjN_728's Avatar
Off-topic but damn you were able to fit 285 in the rear? I have 275 and i thought that was the widest!
Old Jan 29, 2009 | 01:38 PM
G35Papa's Avatar
Hey Nick
If you want to bring it over, I can take a look at it for you. It's possible it's the rear shock tower. There is one bolt that I didnt touch cause it comes pre-tightened from the factory. It wouldn't take long to drop it and tighten it up.
Let me know
Old Jan 29, 2009 | 02:05 PM
officerdbag's Avatar
I fit 285's with plenty of room in the back.. no rolled fenders and I was lowered.
OP, IDK my car gets unstable and rattles like that but that happens when I reach around 110
Old Jan 29, 2009 | 02:07 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
try that bolt your friend was talking about.. but im guessing its the shock tower
Old Jan 29, 2009 | 02:09 PM
ttrank's Avatar
Grocery getter
Wheels/tires the same? Thinking it may be a balance issue...
Old Jan 29, 2009 | 03:07 PM
nchima's Avatar
Originally Posted by G35papa
Hey Nick
Let me know
Chris, I might bring it back so you can take a look at it, I'll PM you when I get some time. Yea, it gets a little unstable at high speeds as well.
Old Jan 29, 2009 | 04:12 PM
nchima's Avatar
So I was driving today and omw home I noticed the car was wobbling a LOT. I looked at the rear tires, and WOW! They are shot, the inside tread is LITERALLY just ripping off the tire. I don't know why/how this happened, but I got to get new tires now. Sigh.
I'm going back to 275's...
Old Jan 29, 2009 | 04:49 PM
gary c's Avatar
From the wear you mentioned on the rear tires apparently you didn't get a
four wheel alignment or the toe adjusters were NOT installed correctly. How
bout the front, without adjustable a arms you'll be going thru tires on that
end too. I just went thru all this, it's imperative to get the alignment right
since quality tires are big $. You shouldn't be hearing any noises either
other than "Tire Roar" from worn tires and misalignment....G/L
Gary
Old Jan 29, 2009 | 06:12 PM
Cubanl81's Avatar
^^^ +1. I know a guy that has 295 in the back. So its not the 285.
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
