new owner with questions on fuel, door locks and service engine light
Old Mar 1, 2009 | 07:54 PM
mike_013106's Avatar
I have a 2003 g35 and my driverside door lock dont work......and I found this site and I'm thinking about order it from there but just wanna know if anyone has ordered anything from there before?
http://www.trademotion.com/partlocat...ator&siteid=55
and if thats the part I need? or is there anywhere I can get it cheaper? and my passengerside door lock stops working after I lock and unlock it about 5 times..should I replace it too?
Old Mar 1, 2009 | 07:56 PM
this is the part # 80501am80a
Old Mar 1, 2009 | 08:05 PM
kernel's Avatar
SEC > Big 12
Welcome to 'Driver Mike.
I can't get anything to come up with that part number...
do you mean it won't work when you use the keyfob and/or push the the button, or you can't even manually lock the doors?
If it's the former it is your door lock actuator, and lots of people here have had to replace them. If they aren't working or are causing problems replace them and it should solve your problem.
Old Mar 1, 2009 | 08:10 PM
gas for 2003 infiniti g35?
do you have to put super or can you put regular? does it make a big difference?
Old Mar 1, 2009 | 08:13 PM
kernel's Avatar
SEC > Big 12
Premium fuel is required for our cars, preferably 93 but 91 is okay as well. Some say it doesn't make a difference, but the general consensus is yes it will.
My opinion is if you can't afford the difference in gas you probably shouldn't even have the car, but that's just my .02.
O HELLA OEM's Avatar
93 octane all day
Old Mar 1, 2009 | 08:17 PM
but I just bout it...so I dont know what gas it has had for the last 5 years....so if it has had regualr all this time is it woth putting 93 in it?
Old Mar 1, 2009 | 08:18 PM
kernel's Avatar
SEC > Big 12
What makes you think it had regular in it the last 5 years?
To answer your question, let me put it this way. Lets say you smoked for the past 5 years, is that any reason to not quit smoking? Of course not. Two wrongs doesn't make a right.
Old Mar 1, 2009 | 08:20 PM
service engine soon?
I'm getting that light on,,,,and it says emissions....what can it be? something serious?
Old Mar 1, 2009 | 08:26 PM
kernel's Avatar
SEC > Big 12
threads merged....if you've got a lot of questions about your new G please post them here rather than creating tons of new threads, particularly since all of these topics have been covered multiple times.
Old Mar 3, 2009 | 02:41 PM
took it to autozone and this is what it said....
P0442
Definition
BBEVAP control system small leak detected
probable cause
BB1 EVAP Purge Solenoid faulty
BB2 Canister vent solenoid faulty
BB3 Blocked vapor canister
BB4 Faulty EVAP pressure sensor
BB5 Loose or defective fuel cap
what should I do? and how can I reset my check engine light to see if it comes up again?
and about the actuator where can I get it the cheapest?(I dont have a keyfob...and the power lock dont work but it works for the passenger side)
Old Mar 3, 2009 | 03:38 PM
tt88supraman's Avatar
Originally Posted by O HELLA OEM
93 octane all day
ha we dont have 93 in CA
Old Mar 3, 2009 | 11:26 PM
I have another question
I just bought a 2003 infiniti g35.....and it has a flip down screen and under the passenger side seat it has a dvd player...it says delphi delco electronics systems on it.....it looks like something from a dealer....my question is how do you turn it on or is there a fuse for it or something because I cant get it to work?
Old Mar 6, 2009 | 04:51 PM
scrapiron7's Avatar
Originally Posted by mike_013106
P0442
I started throwing this same code 2 days ago. I checked my gas cap, it was tight so probably not the problem. I'd also like to know how to reset the ECU to see if it was the gas cap.
Bump.
mike730
Jan 12, 2018 04:25 PM
xluke
Jul 30, 2016 01:48 PM
ClwMike
Jul 23, 2015 12:55 PM
apintojr
Jul 23, 2015 10:52 AM
igking
Jul 19, 2015 01:12 AM
