quick help.. window motor..
Old Jun 1, 2009 | 09:46 PM
2fast's Avatar
hey will the nissan window motor work for my 2006 infiniti g35 coupe?
Im asking because my motor seems to be broken and im in panama and theres only nissan dealerships here, not infiniti..
Old Jun 1, 2009 | 11:30 PM
0MGHI2U's Avatar
if the part number is the same then yea.. but i doubt it since the z and g door frame is diff size..call nyc infiniti dealer...i ordered mine online for mad cheap.. oem
Old Jun 1, 2009 | 11:33 PM
0MGHI2U's Avatar
Old Jun 2, 2009 | 04:08 AM
2fast's Avatar
All well my window is down and wont roll up.. ive tried banging it hard, etc, wont work..
Like i said, im in panama, so if i order another one itll take a bit to get here.. pffft..
Old Jun 2, 2009 | 11:34 AM
JPilla19's Avatar
Try this...
I was browsing this site and saw that some other people had the same problem. Someone then suggested that you open the door with the stuck window, then hold the window up button while closing the door.
I have the same problem but only in the passenger side door. I tried what he suggested and it works for me every time. It also works for me to get the window to roll down because sometimes it gets stuck in the up position.
The problem isn't in the motor. It has to be a sensor somewhere that is malfunctioning. Hope this helps.
Old Jun 16, 2009 | 04:28 PM
Cassman's Avatar
That is so untrue. It is the motor. You will need to replace it even if your trick works. There is a DIY somewhere on this site. If you are able, go to AutoZone and order the motor. Bring your old one back to them and get money back. I think it was around $100 to buy the motor and it is easy to do yourself. It is not a sensor problem.
Old Jun 16, 2009 | 04:49 PM
03g35vt's Avatar
Yea its the motor. The trick might work for a while but the motor will go on you probably at the worst possible timing if you dont take care of it. I've already had the fun opportunity of replacing the motor. What you can try however is just cleaning the contacts and the inside of the motor. Sometimes the motor itself is still fine but there is just carbon build up that is causing it to malfunction. And yea there is a DIY somewhere on the forum thats a great write up to do it
Old Jun 17, 2009 | 02:35 AM
silver_7's Avatar
Looks like mine is doing the same thing. Got stuck down for twenty minutes last night. Luckly I got pissed off and somewhat hit where the window motor was located and tried it and it rolled back up. I havnt rolled it down since....lol. Im gonna order my new passenger switch friday. But just like everyone said its the motor.
Old Jun 17, 2009 | 08:46 AM
JPilla19's Avatar
Good input. You are all wiser than I.
Dallsinghjr1
Sep 17, 2023 11:25 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
