My wheel was hot to the touch when changing to winter setup!
Old Oct 1, 2009 | 09:21 PM
kidtronix's Avatar
Optional
Old Oct 1, 2009 | 09:48 PM
loki05's Avatar
is your pads low or almost worn out?
Old Oct 1, 2009 | 11:23 PM
snou52's Avatar
wheels get hot man...its normal
Old Oct 1, 2009 | 11:27 PM
jcaramia's Avatar
I am pretty sure he realizes that, but when one is abnormally hotter than the rest, there could be a problem in that area.
Old Oct 2, 2009 | 09:09 AM
thatguy II's Avatar
Sounds like a brake is dragging. Might try exercising your caliper to see if it is binding or stuck or just plain ol' cruddy.
With the old pads still on, pull the caliper and compress the piston in, REINSTALL caliper then pump the brakes. Repeat. This will get the piston to cycle in and out perhaps freeing it up.
Also clean and grease the spots where the pad rides against the caliper bracket. If it is all cruddy and dirty there the pad might not be able to relax away from the rotor.
Old Oct 2, 2009 | 10:08 PM
g35dalf's Avatar
A hot wheel is not normal. Definitely the pads are rubbing - your calipers are seizing or dirt behind the caliper (as thatguy said). Definitely re-grease the back of the pads and clips or it's going to seize again.
drew131
Apr 22, 2018 05:49 PM
WxAxGxS
Apr 27, 2013 12:44 AM
G35phile
Jun 12, 2011 10:19 AM
Igor1080
Feb 23, 2010 12:07 PM
2004G35coupe
Mar 12, 2007 03:12 PM
