question about tire size for my 19'' wheel
Old Oct 17, 2009 | 10:55 AM
player027200's Avatar
i have a 04' coupe and i just bought a set of 19''. they are 19/9.5 +25 and 19/10.5 +22. I wonder what would be the perfect size of tire for them?
Old Oct 17, 2009 | 11:19 AM
tragedycat's Avatar
275/35/19
285/35/19
Up to you.
Old Oct 17, 2009 | 04:10 PM
whats the difference between these two?
Old Oct 17, 2009 | 04:14 PM
tragedycat's Avatar
Different widths...I've had both setups on 9.5/10.5 wheels and frankly they felt the same to me. Although I like the fatter tire look, but on the other hand narrower tires are cheaper. So it all depends on what's important to you.
Old Oct 17, 2009 | 05:21 PM
HenryLee's Avatar
Originally Posted by tragedycat
245/35/19
275/35/19
285/35/19
Up to you.
+1 as easy as cake~
Old Nov 14, 2009 | 01:17 AM
Mr_pharmD's Avatar
how about 245/35/19 and 285/35/19?
Old Nov 14, 2009 | 11:07 AM
FanOfNissan's Avatar
Here's a nice tool:
http://www.miata.net/garage/tirecalc.html
If the new tires' overall diameter isn't greater than +/- 5% of OEM size, you'll ensure the traction control won't get wacky.
Old Nov 14, 2009 | 02:21 PM
gary c's Avatar
With your rim size you can run 245/35F and 275/35R that's what I've been using for several years without any issues. You could go one size larger like 255F & 285R with your rim size but they'll look the same and cost more $.... Now concern yourself with buying quality tires!
Gary
Old Jan 10, 2010 | 04:11 AM
Fongyd85's Avatar
2005 g35 coupe
Hey do any of you have 19's and wish you went with 18's? or vice versa. I can't decide. I dont know the width and offsets I should go with either. I notice a lot of you go staggered where the fronts and backs are different but do you think I could go with all 4 the same size so that I can rotate wheels? I don't plan to do much with the G just rims and a front lip. I like how the rims with lips look. I like the big rim look but don't want too much sensitivity to bumps and potholes. I know it's a pretty blunt question but I'm not good with wheels.
Old Jan 10, 2010 | 10:49 AM
gary c's Avatar
How bout bought 18" Volks and wished I had 19" and after a considerable cost I made the switch. There's no problem using the same offset front and rear. I did that on my last Z for several years and ran 245s front and rear.
Gary
Old Jan 10, 2010 | 11:27 AM
idrive_MD's Avatar
no regrets going with 19's, I felt like the ride actually improved. It certainly gave me the needed height boost I required. My tires were too short when I was 18's...my only regret is that not many tire manufactures make a 295/35/19, so I just went with an affordable but good pairing of 255/35 and 295/30.
Old Jan 10, 2010 | 11:37 AM
Deezflip's Avatar
^I have these sizes....it feels pretty good with the VDC for some reason and the slip light doesn't kick in as often. As far as looks and the only thing that bothers me about it is that the 245/35 seems too unproportional to the fat 285/35in the back.
Old Jan 15, 2010 | 07:12 PM
Fongyd85's Avatar
hey I'm planning on ordering a wheel and tire package R1 racing drift 19x8.5 front and 19x 9.5 rear. Im going to order faulken fk 452 with them and need a second opinion with tire size that i should get with my wheel widths . there options are 245/35/19 front with 245/40/19 rear, 245/35 front and 275/35 rear, or 225/40 front 245/40 rear, 225/40 front with 275/35 rear. I tried doin my research and saw that a lot of you get wider rims so I don't know how to compare. Am I going to narrow with the wheels? It's their only staggered option.
Old Jan 16, 2010 | 10:44 AM
fresh_06'G35's Avatar
^ go with the 245/35 (front) and the 275/35 (rear)
Jusseth
Sep 13, 2020 12:25 PM
vitamin.v
Nov 7, 2019 06:10 PM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
