What if my "low tire pressure" light is on and...
You made no mention of how many lbs you put in your tires but the book calls for 35 PSI. If you drop below 29 LBS the TPS will show on your dash. There's a good chance you picked up a nail, this is something you shouldn't ignore! With our low profile tires it's impossible to spot which tire is low, they all look the same.... Take your G to the closest tire shop and have it checked out.
Gary
Gary
yea about 35-38 depending on how long you've driven
i wouldn't recommend anything above that, could cause a stiffer ride and slightly worse tire wear
that is if you're on stock wheels. and like someone else mentioned, you have to drive for a little bit for the TPS to do it's thing.
