NO Air Con. UK owner. Please help
Jan 10, 2010 | 04:18 AM
Hi Guys, I am a UK owner (RHD) 03 G coupe. Not much help off Nissan over here as it's such an unusual model for them to bother with.
After a cold snap my battery died and was left in a no volt situation for a couple of days. After battery recharged I have somehow lost all power to the AC, defrost, heat and fan control. I have no central display either.
I have checked the obvious (fuses) and can't find any that have blown. Two fuse boxes, one forward on my battery the other by my accelerator pedal (RHD), is that right or is there another on hidden away somewhere.
Everything else seems OK, ABS, mirrors, in fact all the electrical systems are working OK. I have noticed the memory off the seats has been lost but do not know how to re-program these, could I have an EPROM problem.
Thanks for looking and any help will be greatly appreciated.
Reply 0
Jan 10, 2010 | 09:13 AM
On the U.S. models, the circuit board for the heating controls and the radio are all one piece. I know that doesn't make sense, but they are. Did you check the fuses for the radio?
Reply 0
Jan 10, 2010 | 10:38 AM
Sounds like to module went as stated above. Had a similar problem except heat/radio still worked but only on the settings they were at when it went.
Reply 0
Jan 10, 2010 | 11:14 AM
Are ye daft man?
All of Brittan is lookin' like Greenland! You don't need AC...
Reply 0
Jan 10, 2010 | 11:41 AM
There is also a fuse panel behind the battery.
Reply 0
Jan 11, 2010 | 10:03 AM
Radio CD and pop out screen are all good
Reply 0
Jan 11, 2010 | 10:04 AM
Quote: There is also a fuse panel behind the battery.
Behind? do you mean windshild side?
Reply 0
Jan 11, 2010 | 10:05 AM
No Tex, AC is a luxury over here, however a derost facility would help
Reply 0
Jan 11, 2010 | 10:07 AM
Quote: Sounds like to module went as stated above. Had a similar problem except heat/radio still worked but only on the settings they were at when it went.
What did you do to fix it.
Cheers
Reply 0
Jan 11, 2010 | 12:18 PM
Quote: Behind? do you mean windshild side?
Yes
Reply 0
Jan 11, 2010 | 08:08 PM
Quote: No Tex, AC is a luxury over here, however a derost facility would help
When I was a wee lad and first learned to drive, all we had was a towel to "defog" the windshield..... ANY YOU LIKED IT!, YOU LOVED IT!
Apologies to Dana Carvey...
Reply 0
