I think my throw out bearing is goign bad
Old Feb 25, 2010 | 07:10 AM
jwrape's Avatar
Almost to work this morning and push i the clutch as I'm rolling and feel a vibration in the pedal as well as hear a swirling sound. Feels like rough, dry ball bearings.
Scared it's the throw out bearing.
What do you think?
Old Feb 25, 2010 | 08:21 AM
Bri127mx's Avatar
im not sure about g35's but this is what was happening to my '55 f100 before i did the bearing
Old Feb 25, 2010 | 08:43 AM
DuaneB's Avatar
sounds like it could be. If you are stopped, sitting in neutral (engine running) and start pushing down on the clutch pedal does the noise start? And then stop when you let the clutch pedal out? If so, I'd be pretty certain that it is the throwout bearing. Not an expensive part, but as you're probably aware the labor could be expensive. (I just changed my clutch/flywheel/bearing this week).
Old Feb 25, 2010 | 11:01 AM
Iamnotkento's Avatar
Im pretty sure thats your throw out too. If you do decide to change it, i suggest you to replace your pilot bearing,throw out bearing, clutch,flywheel too. Mind as well replace all those while you can.
Both bearings are pretty cheap, but like someone said if your not doing this on your own, labor will be pretty expensive.
Old Feb 25, 2010 | 03:05 PM
str8dum1's Avatar
you dont have a pilot bearing, you have a pilot bushing. little need to replace the bushing unless you were upgrading to the Nismo roller pilot bearing.
Old Feb 25, 2010 | 09:28 PM
DosEquis's Avatar
sounds like your throw out bearing.
Old Feb 26, 2010 | 06:57 AM
jwrape's Avatar
Funny, it's being intermitant. Sometimes I feel it, sometimes I don't. I drove it home 50 miles yesterday from work and felt it ever so often but not every time I pushed the pedal.
Old Feb 26, 2010 | 10:15 AM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
how many mi's on your car
when your sitting at a light you don't leave it in first with the clutch in do you? if you do like many do, thats why your bearing is going before the clutch.
Old Feb 26, 2010 | 10:17 AM
jwrape's Avatar
Just hit 130k miles. Lotta miles for a 05' I know. I drive 100 miles a day.
I do sit at the light in 1st if it's a short light, if it's a long one I pop out.
Old Feb 26, 2010 | 11:48 AM
danielj's Avatar
i c. yah, replace that hole thing, your clutch is probably close to done anyways. hows the car running other then that anyways, never seen to many at that many miles, wondering how mine will run when it gets up there (i have a 05 also, but with 28K miles)
Old Feb 26, 2010 | 11:50 AM
jwrape's Avatar
It runs perfectly. I need to replace the plugs, just for maintenance reasons, but it runs like a scolded dog.
I just contacted the previous owner and he said the clutch was just replaced before I bought it. Hmmmm. I wonder if it's the TOB at all.... Stange. So if that is true. I got the car with 114,000 last June and it now has 130,000, so 16,000 mi. later...
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
wuzz-upp
Oct 3, 2015 04:21 PM
g35coupe2
Sep 17, 2015 04:00 AM
n2fooz
Sep 4, 2015 07:46 PM
