Car not starting, alarm? vehicle immobilizer system?
Old Jan 27, 2019 | 10:07 PM
  #31
vijayrishi's Avatar
infiniti, awd
But it does not always happen. Happens once or twice a year.
Old Jan 27, 2019 | 10:08 PM
  #32
vijayrishi's Avatar
infiniti, awd
Has been happening for 5 years or more. It should happen more often if starter is defective.
Old Jan 28, 2019 | 12:08 PM
  #33
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Next time it happens look at the NATS indicator light.
Old Jan 28, 2019 | 03:53 PM
  #34
vijayrishi's Avatar
infiniti, awd
Thanks will do, next time it happens. In a few months...
It is working fine now...
Vijay
Old Feb 23, 2019 | 11:46 PM
  #35
Roger44's Avatar
g35xS sedan all options
What if it’s the yellow key warning light(2008 g35xS)
Old Feb 24, 2019 | 01:02 AM
  #36
Blue Dream's Avatar
I drove ttrank's car solo
Post that question over in the 2nd gen G35 forum. https://g35driver.com/forums/g35-sedan-v36-2007-08-217/
Old Feb 24, 2019 | 08:51 AM
  #37
vijayrishi's Avatar
infiniti, awd
If it is, what do I do? Since the last occurrence a while ago, the car has been starting fine. It only happens once or twice a year, but very inconvenient when it happens. A truly weird problem.
Old Apr 3, 2019 | 10:10 PM
  #38
Duece35z's Avatar
Sedan 4 door
Same problem sedan 04
Originally Posted by Sean Tyler
Im interested in this. swapped a new vq in my g35 after i spun a bearing at the track. engine was out of a 05 350z performance which from everything i could find its non rev up. issue is i didnt know there was a difference in 350z harness vs g35 well besides the o2 sensor plugs being different, missing a plug for ac and an extra plug in by the ecu which i believe is for the oil gauge, and that the ecu plug is pinned out different. i tried to start the car using the 350z harness and no fuel pump prime and no spark. took that harness off and went back to the original g35 one. fuel pump primes and it turns over just no spark which i believe is from the security system. (red light stays solid when key turns to "ON" position.
Also my car is not 100% together some interior stuff is unplugged and the very front body harness. everythign on the engine and trans is all plugged in.
i need some help as i was trying to make the two day season closer drift event!!!!!
are you still having the problem did you get it fixed I’m having the same
Old Jan 25, 2021 | 08:22 PM
  #39
Char Holland's Avatar
New engine switch put in
Reset the alarm.i lost the original key had a new switch put in and cant start my car
Originally Posted by seymore4
If its NATS (Nissan Anti Theft System) you can disable it with an Uprev reflash, lots of guys do this when then get tuned so that they can use unprogrammed keys (Its like $200 just to reprogram the key at the dealer). You can't just mechanically disable it though. PM me if you want to give it a try, I've done it many times
NEw key lost original one my car will not start once I turn it off.how can i either bypass yhe alarm disconnect it or reset it.please tell ke how to do either of those
Old Jan 26, 2021 | 04:23 PM
  #40
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Did you have the new key registered to the car?
Old Jan 26, 2021 | 07:12 PM
  #41
cleric670's Avatar
BANNED!!!
So you're telling me you can start the car with the new key, but if you turn off the car it won't restart until what...? the next day?
Old Mar 14, 2021 | 06:35 AM
  #42
Stefanie's Avatar
infiniiti g35
Originally Posted by Jsprrp
. I could really use some help figuring out how to do an uprev reflag to bypass the security on my 2001 Infiniti qx4. Thanks in advance
you think there is anyway possible u could help me with getting info on how to begin this process?
scumbagsleeper
Mar 13, 2019 10:30 AM
Menotti
V36 Audio, Video & Electronics
Apr 21, 2010 11:59 AM
dgbos4
Jan 20, 2009 12:51 PM
pumpkinmomma
Nov 9, 2008 09:58 AM
jcs1957
Jan 7, 2007 11:41 PM
