what rotors ? - please recommend
Old May 25, 2010 | 05:06 PM
rydeordie07's Avatar
Brakes what rotors ? - please recommend
Hi i made the mistake to resurface my oem rotors when i replaced my pads (HP HAWKS) and now my car shakes like there is no tomorrow under moderate breaking.. i am on a budget and would like to know what you all are using and what you all recommend.
Thanks in advance.
Old May 25, 2010 | 05:41 PM
ahmgood's Avatar
I have the same problem. I did my rear brakes had rotors turned ect. One thing I learned is to put the OEM shims in. My rotors somehow warped due to no shims or something. I thought the shims on the new pads were ok but they weren't.
Good luck!
Old May 25, 2010 | 05:55 PM
VQ Johnny's Avatar
did you bed in your pads properly? it is unlikley that the rotors are warped but more likley that you have excess pad material built up on one spot of the rotor causing the shutter you describe. if you need new rotors try the Napa ultra premium rotors, not to pricey, I use them for my oem brembos.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old May 25, 2010 | 05:58 PM
ahmgood's Avatar
I took my car into the dealer thinking it was a wheel bearing, they are the ones that told me the rear pads were new and missing the shims and one of the rotors were warped. I'm going to add the shims see if that takes the shake away if not gonna replace the rotors. Dealer wanted $375 to replace and fix. SCREW THEM!
Old May 25, 2010 | 06:28 PM
VQ Johnny's Avatar
read the article in the link I gave you there is no such thing as a warped rotor!!!! the shims aren't going to do a thing for you the best you can do is try to properly bed (I know the Hawks come with bedding instructions) in the pads and maybe it will go away if not... turn them or replace them, then PROPERLY bed in your pads its the most important part of a brake job when done properly it will extend the life of both the pad and rotor and increase your stopping power.
Old May 25, 2010 | 06:34 PM
VQ Johnny's Avatar
Here is the bedding process if don't know how
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
Old May 26, 2010 | 07:48 AM
grovefromnh's Avatar
As a sports car racer of 30+ years, I learned to bake my pads before installation. Get an old toaster oven, put it outdoors. Put in pads (don't overlap them) set temp for 350, bake for 30 minutes. Shut off oven. DO NOT open oven until pads are cold as the introduction of cold air when the pads are hot will make them brittle. Doing this will cut down on the pads outgassing, making them pretty much ready to go.
Old May 26, 2010 | 09:15 AM
lost hybrid RF's Avatar
Interesting ^^. Never heard of that before.
Old May 26, 2010 | 09:43 AM
G35Lopez's Avatar
Correct me if I'm wrong, but isn't it so that not all pads require shims. For example I purchased oem-replacement semi-metallic wrangler pads both f&r and the factory shims couldn't be applied. I properly bedded in the pads using the stop-tech process. I've now had them on for a little under a month and no problems experienced. Is it possible that I’ll experience an issue some time down the road. BTW the front rotor are new wrangler oem-replacements and the rear are factory oem just turned/cut/resurfaced.
OP, if you're not planning on any track days and just enjoy daily driving any over the counter replacement should be fine. Just stay away from the eBay stuff. They might look nice but they are cra*
Old May 27, 2010 | 12:41 AM
b1gk1d's Avatar
search google for racingbrake they used to be here and i bought my pads and rotors from them. great A+ product!
never get a chance to write review about to thank them.. but here we go i guess
A+
Old May 27, 2010 | 01:45 AM
VictoriousG's Avatar
Well if you're on a budget I've heard good things about 89 rotors but I have never personally used them Iam currently running stoptech slotted rotors they're great for a quality rotor.
Old May 27, 2010 | 06:27 AM
I've used EBC dimpled and slotted rotors on my last 3 cars.
Picture Share
Feb 4, 2018 12:41 PM
dseet
Oct 11, 2015 12:40 AM
nanobotking
Oct 8, 2015 08:40 AM
alinero718
Sep 27, 2015 09:35 PM
