stuck in neutral?
Old Jun 22, 2010 | 08:56 PM
shawnpl's Avatar
stuck in neutral?
So i was driving and i switched into the tiptronic and then the car stalled. it wont shift gears and it doesnt show anything where it says what gear im in. when i try to switch back into drive, the shifter wont stay there and it shows neutral if i hold it there. any ideas what this is?
Old Jun 22, 2010 | 08:59 PM
jibberjabbers's Avatar
Stalled with an automatic? LOL
Can't help you here. No idea how the G35 auto tranny works.
Old Jun 22, 2010 | 09:16 PM
junCakes's Avatar
Originally Posted by jibberjabbers
stalled with an automatic? Lol
can't help you here. No idea how the g35 auto tranny works.
lol
Old Jun 23, 2010 | 11:31 AM
wise-1's Avatar
What you need to do is take the center console apart and wiggle the shifter gate a little.
One of the screw's that hold it in place doesn't always thread in properly, so loosen, then tighten each screw while wiggling the shifter. It should go back into place.
I wish I had a picture, but it wasn't my car that I fixed.
Old Jun 23, 2010 | 12:05 PM
walshtj's Avatar
That sucks you "stalled" in an AT...
Old Dec 10, 2010 | 06:59 PM
TimTran's Avatar
It might be your air-filter sensors being blocked or touched can cause it to stall. Not entirely sure, but that is a possibility.
Old Dec 10, 2010 | 07:09 PM
Metalp3n's Avatar
Happened on my car before. Ended up that I needed new shifter linkage as mine was bent after a very very bad pothole.
Old Dec 10, 2010 | 07:32 PM
gtoor1990's Avatar
^^^ I know someone local who had the same problem with an 5AT ... He had to replace shifter linkage as well...
Old Dec 10, 2010 | 07:56 PM
BIGD28's Avatar
+1 for the shifter linkage
Old Dec 10, 2010 | 10:25 PM
the_sedan's Avatar
ive seen the shifter assembly break before and it gets stuck in manual mode.....as i've replaced a few of them before.
Old Oct 10, 2011 | 12:32 AM
hi-tek22's Avatar
How much does something like this cost
Old Oct 10, 2011 | 06:58 AM
adamls2's Avatar
DAMN that sucks, i have never heard of something like that before!! and also LOL at stalling with a/t that just sounds so bad!!
Dallsinghjr1
Sep 17, 2023 11:25 AM
magnetism80
Feb 1, 2019 10:00 AM
Thebaws11
Nov 30, 2016 12:54 PM
Since 1983
Sep 19, 2015 10:26 AM
