Best Tranny and Diff fluids
Old Sep 3, 2010 | 01:13 AM
rob40wilson03's Avatar
Hey guys, I want to change out my transmission fluid and differential fluid
EDIT: I have a 6MT
I found this thread https://g35driver.com/forums/g-spot/...you-use-2.html
but its a pretty old thread with not many results.
Are people still pretty fond of the Amsoil 75W-90 Transmission & Transaxle fluid for the transmission and the Sever Gear 75W-90 for the differential?
**NOTE: I have the Limited-slip Diff
Thanks for your suggestions!
Old Sep 3, 2010 | 07:57 AM
M302_Imola's Avatar
Mobil 1 fully synthetic 75w90 in diff and tranny. You will need 6 btls.
Old Sep 3, 2010 | 01:05 PM
anyone else have experience with Mobil1 in the tranny and diff?
Old Sep 4, 2010 | 03:29 AM
gqraverice's Avatar
Someone correct me if I'm wrong, but I think I read somewhere that the OEM tranny fluid is the best for the 6MTs.
Old Sep 4, 2010 | 03:36 AM
nate704's Avatar
Redline FTW
Old Sep 4, 2010 | 08:07 AM
VQ Johnny's Avatar
You're right only use GL4 in the tranny, GL5 has additives in it that can damage the syncros, OEM is your best bet but IIRC Redline also makes a GL4 MTF.
Old Sep 4, 2010 | 03:06 PM
OGKushRob's Avatar
i was gonna change my stuff soon too. whats the best for an 06 5AT?
Old Sep 4, 2010 | 03:25 PM
doeboy's Avatar
I'm finding it hard to find te GL4 fluid. I bought some GL5 Mobil 1 fluids but I want to use the proper GL4. Whats some good GL4 fluids to use?
Old Sep 4, 2010 | 03:29 PM
thescreensavers's Avatar
Mr.202?
If you have a Stock VLSD then any Diff fluid will work.
Personally I used Amsoil SVG with my Diff which has the VLSD, you do not need any diff additives for the VLSD since its sealed inside.
Old Sep 4, 2010 | 03:37 PM
doeboy's Avatar
So your saying that I could use the Mobil 1 75w90 GL5 in my Tranny?
Old Sep 6, 2010 | 10:53 PM
bump
Old Sep 7, 2010 | 01:08 AM
gqraverice's Avatar
I've gone with OEM tranny fluid twice.
http://www.mynismo.com/products/?id=3920
Old Sep 7, 2010 | 06:43 PM
Nismofan240's Avatar
i run amsoil 75-90 in my tranny and diff and i think its working very well. no need for the severe gear. you only need that when your doing a lot of towing or putting a big strain on the differential. the normal amsoil gear oil is all you need for daily/spirited driving.
Old Sep 7, 2010 | 07:35 PM
doeboy's Avatar
Is that the GL-5 amsoil or GL-4?
Old Sep 7, 2010 | 09:00 PM
gary c's Avatar
AMSOIL or Red Line synthetics are the best lubricants for your trans/differential, runs cooler/lubricates better and lasts longer. Better choice than OE fluids....
Gary
