clearance lights?
Old Oct 10, 2010 | 11:58 PM
phantomg35coupe's Avatar
clearance lights?
So i just noticed the other day that my clearance lights arent coming on. I checked the fuses and i cant find the one for the clearance lights. maybe im missing something? i already tried searching it with no luck
Old Oct 11, 2010 | 12:14 AM
rob40wilson03's Avatar
what year is your car?
Old Oct 11, 2010 | 12:19 AM
nogoodname's Avatar
maybe the bulbs are dead..
Old Oct 11, 2010 | 12:20 AM
the year is 04 and it could be the bulbs but what are the chances that both go out at once?
Old Oct 11, 2010 | 12:22 AM
dcryan90's Avatar
if it is the fuse your lights for your stereo wouldnt be working either as well as your parking lights
i had the same problem and it was a fuse in the fuse box behind the battery( which was a pain to get to and really annoying)
Old Oct 11, 2010 | 12:26 AM
k thanks could you tell me what fuse it is when i get back there and, do i have to remove anything other than the battery to get back there?
Old Oct 11, 2010 | 01:51 AM
dcryan90's Avatar
there is a a black cover over it that you will have to pull off and it should be the red one in the top left corner.... there is a thread on her somewhere ill post it if i find it but you should be able to search for it
Old Oct 11, 2010 | 01:54 AM
dcryan90's Avatar
actually her it is and it comes with pictures and everything should make the job easier
but next time please search a little before hand and then post when your at a total lose
https://g35driver.com/forums/audio-v...use-blown.html
Old Oct 11, 2010 | 12:53 PM
i checked it out and got it fixed, thanks dcry, and i didnt find that because i was searching clearence lights not side markers
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
knightro g35
Aug 27, 2015 09:31 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
Ashton35
Jul 17, 2015 10:11 AM
