is that screw looking thing supposed to come down that low, it's like an inch from my tire. if i go over a bump it'll prolly pop my tire! i had 19's on and it was even worse so i put the small wheels back on cuz i was worried
it is the upper control arm brushing. It will move up and down with your wheel together, and won't hit your wheel unless that is broken and falling off!!!!!!
oh okay thanks, so it's safe if it's just an inch above my tires?
i looked at my moms maxima and i couldn't even see a similar part above her tire
Screw thing??? Are you talking about the upper ball joint (gold top w/ red boot) if so you have nothing to worry about. The balljoint and the tire move relative to each other
most Hondas have the similar set up !!!!!!!Originally Posted by Cody
oh okay thanks, so it's safe if it's just an inch above my tires?i looked at my moms maxima and i couldn't even see a similar part above her tire
the guys with chargers and magnums have to grind the stud and nut in half when they run 22s and whatnot cuz they hit.
so if i go over a bump that thing will rise with the wheel? lol im jsut afraid its gonna poke my tire
bigc
Wings Nation
close
- Join DateFeb 2007
- LocationSoCal
iTrader Positive Feedback100
iTrader Feedback Score(59)
Liked:626 Times in 456 Posts
your wheel is attached to 'that thing'. they can't move independent of each other without either the spindle or your wheel snapping.
herrschaft
close
- Join DateJul 2009
- LocationCoast
iTrader Feedback Score(18)
Liked:771 Times in 605 Posts
Quote:
is something wrong with my g?
Your missing a wheel......is something wrong with my g?
Invalid_User
close
- Join DateSep 2007
- LocationTampa,Florida
iTrader Feedback Score(23)
Liked:217 Times in 146 Posts
Quote:
