Diy Alignment anybody here do their own?
Old Dec 15, 2010 | 08:18 PM
fatlip's Avatar
I wonder how much this is and how easy it is to use.
Old Dec 15, 2010 | 09:12 PM
AlexAZD's Avatar
I have a friend that I drift with that is a suspension tech for Toyota. Not a dealership, directly for Toyota. He said he can teach someone how to do one pretty easily. It's learning how the setup will affect the drive that is the hard part and requires experience. Those are pretty expensive. You can get fishing line and some jack stands, some heavy bolts and a harbor freight caliper.. oh and a jack of course.
Check this out http://www.ogracing.com/catalog/4-Ga...GNETIC-ADAPTER
Old Dec 15, 2010 | 09:16 PM
Deezflip's Avatar
I was actually looking at a similar one made by ART but that sucka is already $500 and it's only good for toe readings. Not to mention that's only half of the job....you'll need something to level the car, alignment plates to make adjustments, otherwise, there's too much friction from the pavement to the tire. Then you'll need to get tools to get camber and caster readings. You'll end up spending as much as a real digital/computerized wheel alignment machine minus the car lift.
or you can build your own, kinda annoying and tedious setting this thing up though...
http://www.elantraclub.com/forum/ind...pic=15456&st=0
http://www.hotrod.com/techarticles/c...ide/index.html
Old Dec 18, 2010 | 09:07 AM
fatlip's Avatar
I made an alignment jig today with 2 lengths of 1" square tubing and a magnetic level with a digital angld gauge. I can get the camber in a few seconds but i havent tried the toe yet.
Old Dec 18, 2010 | 08:30 PM
fatlip's Avatar
Anybody know the formula to find the degree of toe based on the front and rear measurments? Or what the diffence of the measurements should be on a car with proper toe?
Old Dec 18, 2010 | 09:01 PM
Hotdawwgman's Avatar
I wish i could do this!
Old Dec 18, 2010 | 09:03 PM
thescreensavers's Avatar
Mr.202?
idk, for 80 bucks for a good alignment every 6 months I don't see a reason to spend money on this.
Old Dec 18, 2010 | 09:51 PM
fatlip's Avatar
True but for the price of one alignment u can get the materials needed to gdt your own measurements. And if u have ever done your own suspension work then u know how simple it is to make the adjustments if u had the proper specs.
Old Dec 19, 2010 | 12:08 AM
surma884's Avatar
The stupid mechanics could **** up your car so it's better to do it yourself. I had some moron doing it and he scratched the the center of my steering wheel (where the Mt Fuji logo is). I should've asked them to replace it but instead I asked for a refund. Stupid me.
Old Dec 19, 2010 | 12:16 AM
Mr.202?
True
The place I go to, is extremely good. All the car enthusiasts from my area and nearby areas go to this shop. Good Quality work.
Though if you cant find a shop like that I agree.
Old Dec 19, 2010 | 12:54 AM
fatlip's Avatar
Watch the DIY video on getting the measurements for toe with a tape measure. Its very easy. Next u take those measurements and convert them to degrees and adjust from there.
Old Dec 20, 2010 | 04:44 PM
the04coupe's Avatar
anyone try those lifetime alignments from goodyear,sears,mavis,firestone etc . Seem to be a good deal for 150 bucks
Old Dec 20, 2010 | 08:41 PM
SofaKingG's Avatar
I just pay the 150 bucks for the lifetime alignments at firestone. My time is worth more than this.
Old Dec 20, 2010 | 09:54 PM
fatlip's Avatar
Some people say the same about oil changes but to each his own. Its a bit more complicated than an oil change but knowing how to properly to this would be awesome.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
