Would this ruin my car?
Old Nov 15, 2004 | 09:11 PM
mattks's Avatar
Hey all, I have an automatic g35 sports coupe... yes I know, i'm deprived, I should have gotten a manual one... but it's too late now. Anyways, I was wondering if I were to say... rev to 4000 RPM in neutral and then slam the car into drive... would that do the car significant harm? I'm guessing yes... but I want to hear your opinions.
Old Nov 15, 2004 | 09:26 PM
DragonGcoupe's Avatar
Re: Would this ruin my car?
Please don't do that. For the sake of our community.
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
Old Nov 15, 2004 | 09:31 PM
mattks's Avatar
hahaha i had a feeling it would be bad, don't worry though, I will never do it now. =)
Vic's Avatar
Vic
i second that.. don't ever do that. automatic gearbox is not capable of such abuse.
TB/Black, 6MT coupe
Old Nov 15, 2004 | 09:33 PM
azcougarman's Avatar
The bigger question is, did you ever do it at all?
Old Nov 15, 2004 | 09:34 PM
patrickwong's Avatar
why would you do that?!
Don't disrespect your car like that.
Old Nov 15, 2004 | 09:43 PM
GRider35c's Avatar
i wouldnt recommend this, but it would be better than what youre doing!!!
hold the brakes with your left foot while pressing on the gas, then let go of the brakes... try this at different rpm's and with/ without VDC on...
Old Nov 15, 2004 | 09:58 PM
Finiti35's Avatar
FGC South Florida BOD
Neutral drops and brake torquing will both lead to your transmission's demise. Some people do brake torquing only under certain circumstances (launching at the track, preferably running a tranny cooler, etc). But in either event, 4000 RPM is overkill.
Old Nov 15, 2004 | 11:31 PM
pfizzle's Avatar
I like a dumb *** used to nuetral drop my accord v6 trans for like a one month period and finally outta nowhere my transmission went...i dont recommend this action so take advice for a professional DONT NUETRAL DROP
Old Nov 15, 2004 | 11:33 PM
avs007's Avatar
If you brake torque I heard 2000 maybe 2500 RPM is adequate... Brake torquing isn't nearly as bad as neutral drops...
Brake torquing just causes the torque converter to output a lot of heat... That's why you should run an auxillary tranny cooler if you do this frequently... Of course brake torquing from an excessively high RPM, will cause you to burn your fluid... And hot/burnt fluid is bad for your tranny, cause it'll cause the various seals and such to deteriorate or leak. Leaking solenoids will not engage, causing slips. Leaking/deteriorated seals, can also lead to starvation of fluid, leading to catastrophic failure. (Heat is a slushbox's #1 enemy)
Neutral drops, well.... That just puts a whole boatload of stress on all the components in one big bang. Literally.
Old Nov 16, 2004 | 12:34 AM
GRider35c's Avatar
its not cause of neutral drops that messed up your tranny on your accord... i HAD a 98 V6 EX coupe and went thru 5 trannies, UNDER WARRANTY! my last tranny went at 130,000 and honda still replaced it.
bad year i guess!
Old Nov 16, 2004 | 12:37 AM
GRider35c's Avatar
pic didnt work... here she is
Old Nov 16, 2004 | 07:30 PM
DiamondGCoupe's Avatar
the car is gunna hold back, lag, when u first throw it into gear so ur not getting any further by doing that
'04.5 Diamond Graphite/Graphite
Premium, Aero, Tire Package
Corners, Windows up mod,
BelTronics Rx65 Radar
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
006
Intake & Exhaust
Jul 19, 2015 04:30 PM
