what things typically go wrong at 100k+ ?
Old Apr 14, 2011 | 07:35 PM
apexi957's Avatar
04 G Coupe, almost 90k
i have an extended warranty and am already getting work done for the trans and valve covers for free covered by the warranty
what other things should i look into having done before the warranty expires at 100k? i want to get everything i can done for free by the warranty company while i still can so i wont have to pay for it later.
thanks - D
Old Apr 14, 2011 | 07:37 PM
Hi-TechG35's Avatar
Valve covers, wheel bearings, window motors, door lock actuators, MAF sensor...but if the car was well maintained you should be okay.
Old Apr 14, 2011 | 07:40 PM
redpearl99's Avatar
compression rods
Old Apr 14, 2011 | 07:53 PM
apexi957's Avatar
thanks for the quick replies
i didnt think the compression rods would go bad =/
anything else? i also felt like i was consuming oil. how would they test for that?
cuz if i can prove oil consumption i think i can get a new motor too =D
Old Apr 14, 2011 | 07:54 PM
apexi957's Avatar
and what about things that would go bad at 120k ?
i would also like to replace anything that will go bad in advance - its free man
Old Apr 14, 2011 | 10:02 PM
MADtotheA's Avatar
Don't they only cover things that are in need at the present moment? Just have them or a dealership look over the entire car very thouroughly and then replace whatever it needs.
Old Apr 15, 2011 | 02:39 PM
AuAltima3.5's Avatar
I don't know what exactly your warranty covers, but these items are typical non-wear items that do wear. Hopefully your warranty will cover these:
  • Compression Rod Bushings
  • Transverse Link Bushings
  • Diff/Subframe Bushings (rare, but possible if driven aggressively)
  • Valve Covers (just to round out the list, I know you have this en process)
  • Window/Lock motors (already mentioned)
  • Cosmetic items covered? Yellowing aluminum trim under radio, clock, third brake light
  • Sway bar links (front and rear, but mostly rears from reading on here)
  • Radio working right? I forgot what year car you have, but the 03-04s are notorious for dying.
That's all I've got. Hopefully someone else can add to this list.
Old Apr 15, 2011 | 03:54 PM
savior's Avatar
I just passed 106k, just regular maintenance stuff is to be needed. As long as you take care of your car she takes care of you.
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
Rhinos7777
Sep 6, 2015 05:36 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
